So I’ll start off with what I currently have and am looking to replace. I’ve been running a Dell PowerEdge T20 for a long time, it’s not a NAS and has been used as a home server for running various game servers as well as a Plex server.
It’s quite frankly a monstrosity, taping the PSU to the top like that was required because for some reason Dells mounting bracket makes it impossible to fit a standard power supply in the case due to there being a metal strip in the way which cuts the PSU short by about 1/2 inch. I do have an old GTX960 in this machine.
The machine currently only has mechanical storage, no redundancy nothing fancy whatsoever.
_,met$$$$$gg. arimil@media-server
,g$$$$$$$$$$$$$$$P. OS: Debian 10 buster
,g$$P"" """Y$$.". Kernel: x86_64 Linux 4.19.0-21-amd64
,$$P' `$$$. Uptime: 28d 20h 47m
',$$P ,ggs. `$$b: Packages: 3118
`d$$' ,$P"' . $$$ Shell: bash 5.0.3
$$P d$' , $$P Resolution: 1920x1080
$$: $$. - ,d$$' DE: Cinnamon 3.8.8
$$\; Y$b._ _,d$P' WM: Muffin
Y$$. `.`"Y$$$$P"' WM Theme: CBlak (Blue-Submarine)
`$$b "-.__ GTK Theme: Blackbird [GTK2/3]
`Y$$ Icon Theme: mate
`Y$$. Font: Sans 9
`$$b. CPU: Intel Xeon E3-1225 v3 @ 4x 3.6GHz [27.8°C]
`Y$$b. GPU: GeForce GTX 960/PCIe/SSE2
`"Y$b._ RAM: 5010MiB / 15984MiB
The reason I’m mentioning this, is I would like the NAS to also be able to host everything that I previously used this server for, thus not only being a NAS. From what I’ve researched that means Unraid would be a better solution than TrueNAS.
What I’ve already bought:
6x 14TB WD RED drives (3x shucked from easystore)
Everything else is up in the air, when searching around I found this 4U case which looks like it would be good:
And via a LTT video I found that I should use a USB DOM (I’ve seen lots of reports of peoples Unraid flash drives dying):
Unfortunately, I haven’t seen anywhere to purchase the one listed in the video short of refurbished ones on eBay. So I’m not really sure where to pick one of these up.
As for the mobo, and CPU I’m not really sure what to expect, as stated I often host game servers on here as well as a plex server, so I’d need those in addition to the NAS. I was anticipating throwing a m.2 SSD in there to run as the boot drive for the server so that it had some fast storage for the game servers, but I’m not sure if that’s necessary.
I was also intending to buy a 10G switch to have the best throughput for the drives (to potentially store games on the NAS) although I’ve also seen mixed reports of how viable this is. But I’m not well versed in what to look for.
So to wrap it up the tl;dr:
- Where should I look for buying a USB DOM?
- Any mobo recommendations?
- What kind of CPU should I be looking at for hosting a NAS with 6x 14TB drives as well as a plex/game servers?
- Any recommendations for a 10Gig switch for home use?
That’s all the questions I have for now, any recommendations or info are appreciated.
