BE200 works
I tested one briefly before fitting it to another pc
BE200 works
Would it be possible to replace the wifi card with a Google Coral module?
(no need for wifi, as i want this thing running Home Assistant with Frigate and Coral hardware.
What model would fit? 3 types available…
website coral.ai/products
A/E? B/M? “standard half-mini PCIe card”?
Are those things even useful anymore?
Thanks @shonk, i was betting on the A+E also. (looking at the pictures)
@compy386 i plan to use it for Frigate (in HA). (ML/AI detection of persons, cars,… by my security cams)
Hi I have issue with my T8. When I added new nvme 1TB disk Crucial micron works well one day and disk disapeard no in bios. Disk is ok I tested 256GB hynix same issue? Maybe I need to set something in bios but I have no idea what? Back to stock disk and T8 back to work again.
just opened it up… not that difficult but the antennas are VERY difficult te remove from the wifi AE module… Cracked one off. Those connectors are always a PITA, but here, it seens that they put some glue on it also.
Hope the Coral TPU arrives any day now, so the wifi module will not be used anymore.
Just a heads up: coral works flawless
