My PC build Done. Will it work?
I spend the weekend building a PC with a 700$ buget here it is.
http://pcpartpicker.com/p/rKGZ
Here is the RAM cause PCpicker couldn't locate it :(
http://www.newegg.com/Product/Product.aspx?Item=20-104-173&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=2
Will this PC work? Im just looking for a yes, no answer :)
Here is the page for the RAM
http://pcpartpicker.com/part/kingston-memory-khx1600c9d3k28gx
All the parts are compatible, pcpartpicker is telling you to use a case with frontside usb3.0 since that mobo supports it. The 200R should fit the bill. As for whether or not it will turn on, that remains to be seen i guess?
Thanks for finding them :P
Also I like the HAF 912 more (that other one is very ugly )  and I dont really use USB 3 often enough
For future parts if you can't find them just control-f and search the part #
It appears the kingston memory wont work with my build :(
 Edit:
Fixed Ramm issue :http://pcpartpicker.com/p/rLbr
Edit2:
Switched to G.Skill Ares Blue (2x4gb)
These should work and are pretty good from what I hear.
http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbrl
Edit:
They also have a lower Cas than the single Kingston stick
Thanks for your help Im now purchasing it :)
Hopefully it'll all arrive before Christmas.
If Im extremely lucky, before the last day of hanukkah :P
Nice, I just ordered my parts last night. I am splitting the price between my entire family and myself as my Christmas :) I keep telling people I'm rigging Christmas.
http://pcpartpicker.com/p/rKso
spat, I wonder if there is a MicroCenter near you.  Check their website for locations.  They currently have i5 3570k for $169.99 (in store only)  AND they might still have a promo of $40 off with purchase of motherboard.  I recently purchased mine from there and by buying motherboard and cpu together, I paid same price for motherboard as at newegg but paid $129 for i5 3570k!  :)
remember... dont put case door on until it boots and you load bios lol
