This is an overall build, not strictly about water cooling.
Suggestions are welcome.
Basic system specs:
NZXT Crafted Series Black/Green Phantom case
ASRock Z77 Pro4 Motherboard
i5 3570K @ 3.3GHz
Crucial Ballistix Sport 32GB (4x8GB) of 1600 RAM (9-9-9-24)
2x Kingston HyperX 120 GB SSD
NZXT Hale82 750W PSU
Update: EVGA 4GB FTW+ Edition GTX 680
The overall theme is Black and Green. Preferably Acid Green where possible. This is the build I will run with as I build up the watercooling components.
I'm also going to be extensively (imo) modding the NZXT Phantom case by adding side windows (using a dremmel) and removing the 3.25" drive bays to make room for the reservoir and pumps which I've already done. I'll likely put the SSD's on the underside of the 5.25" drive bay using Industrial Velcro (idea stolen from Linus at NCIX) and leave a pure storage HDD at the bottom of the 5.25" bay secured with velcro as well.
Watercooling components:
T-Virus UV Green Reservoir (It glows green under UV light)
Feser One Cooling Liquid - UV Green
Feser One Acid Green Tubing
EK's Supremacy Plexi-Nickel CPU waterblock
Style of all fittings that will be used
2 UV Cold Cathode lights
Update: EK's EVGA GTX 680 FTW edition Acetal + Nickel GPU Waterblock
After that, there's the radiator, pump, and the like, the things that aren't so aesthetically pleasing.
But that's essentially it. It's becoming epic (in the process of building/modding right now). Like I said, suggestions are welcome.
Update (12/13/2012):
I've considered how I'm going to do the side panels, and I believe I will have 4 windows set up in a fairly "popular" Phantom side panel mod. I liked the look of it, so I decided to go with it.
Picture of window mod (not my case or picture):
Except, make all 4 sections windows rather than just 2.
Now, the Top Right window would just show the 5.25" Drive bay cage, which I could add something cool to look at, but I'm not. I'm going to make that into a "stainless glass" kind of window. It's not going to be glass (more than likely it'll be acrylic), but what I mean by that kind of window is that it will portray an image. Made out of different colors of material. More than likely, those colors will just be different shades of green. If I could just find a way to make the image in my head real, it would be amazing. If I can't, then it will be a pane of Acrylic with the same image etched into it. We will see.
The same might happen to the Bottom Left since it would just look at the PSU. Or I might mod the PSU case to look cool. We will see (I say that a lot, I know).
Bottom Right will be either the Reservoir and Pump, or it will be another image similar to the Top Right.
Top Left will be clear and obviously be to look at the loop/hardware. Maybe something etched into the very top left corner, but probably not.
As for the loop, There will be a 3x140 radiator in the top. It will go down to the Reservoir which will go into the Pump, then to a 2x140mm bottom/side radiator, then GPU's, then CPU/Motherboard, then back to the top radiator.
This is where the 2x140mm radiator will go, or it will go along the front rather than the bottom. Still haven't decided. :| Whichever might be easier.
Note: That's my actual case+PSU btw.
I'm also considering flipping the motherboard tray from one side to the other inside the case so that the motherboard is upside down so that the GPU's waterblocks are facing up to be seen rather than the PCB's. If I do that, flip everything horizontally.
All that would require is a tool to remove rivets and looooots of nuts+bolts as I would probably take the entire case apart so I could easily do as I please with each section individually.
If you look back at that window mod picture, you'll notice there's a bit of space above the windows on the side panel that's unused. Either I could extend the windows, or I could cut some wording out up there. I'd prefer the latter, but what do you guys think?
Suggestions are welcome, as I've said. Project name ones in particular.
