Hi, I'm new to building PCs so I would like some help with my build. This is going to be a gaming build.
1. Are these parts compatible
2. Any better parts
3. I'm trying to keep my build at least below $1300. I'll be fine if i go just a bit over
CPU: Intel Core i5-3570k Quad-Core Processor 3.4GHz LGA 1155 (I plan on overclocking and yes I know that the Sandy Bridge can overclock better but I'd like your guys' opinion first) $215 (Amazon)
CPU Fan: NZXT HAVIK-140 CPU Cooler w. Dual 140mm Fans $57 (buying it with a friend, $4 off, YAY!!!!!1)
Motherboard: ASRock Z77 Extreme4 LGA 1155 Intel Z77 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $120
GPU: XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFirex Support Video Card (I plan on overclocking) $240
RAM: Mushkin Enhanced Blackline 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model 994015 (I plan on overclocking) $115
Storage: Seagate Barracuda ST1000DM003 1TB 7200RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $80
Power Supply: XFX Pro750W XXX Edition Semi-Modular 80Plus 750 Watt Power Supply (Silver) $104 (Amazon)
NZXT Switch 810 White CA-SW810-W1 Steel/Plastic ATX HYBRID Full Tower Gaming Computer Case (I want a full tower case because I might want to upgrade later and that I couldn't find any good ATX Mid Tower cases that could fit my fan. If you know a good ATX Mid Tower go ahead and tell me) $170
Case LED: BitFenix BFA-AAL-20WK6-RP Alchemy Aqua LED-Strip White 20cm (I know these aren' needed but I like them. If you can get rid of these to get something better like a graphics card or something else, go ahead) $21
WiFi: ASUS PCE-N15 Wireless Adapter IEEE 802.11b/g/n PCI Express 300/300Mbps Transfer/Receive Rate 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPS support $27
Operating System: Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack $90
I found all these parts at Newegg except for a few that I found at Amazon (shown in the build) and they all added up to about $1250 w/o shipper. If you can suggest any other places that are cheaper, go ahead.Thats my entire build. If you find any things that a some what casual gaming computer doesn't need, then go ahead and tell me. Thanks
