I was just wondering if anyone would help me out with my first build and tell me if the following parts are compatible with one another. I plan on adding a graphics card when i get the money but untill then i will use the integrated graphics. It would be great if you guys would offer suggestions. thanks!! (this will be a gaming PC)
NZXT Phantom 410 CA-PH410-B2 Black Steel / Plastic ATX Mid Tower White Trim Computer Case
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000
ADATA Premier Pro SP900 ASP900S3-64GM-C 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
Thanks for the help!
