My desktop has an unknown microphone
I seem to have a microphone active on my desktop PC. It is a Beelink SEi10, a mini PC with intel 10th gen core i3. I didn’t even know there is a mic active until I booted windows 10 (I use linux and occasionally have to boot to windows through windows 2 go). Sure enough, there is a device getting a microsoft driver for it, appearing as a HD device on HD bus. I have NO external mics attached and even if I remove my speakers from the 3.5mm jack, mic is still active and I can see the noise spikes when I generate noise. I opened up the device, but I couldn’t find anything resembling a mic.
How can I discover what device this is?
How to disconnect it?
Open Device Manager, go to the Audio section, and see what’s listed there. Right-click, properties will give you some details. Also search “Sound Settings” in the Start Menu, and have a look at that list.
If you aren’t sure what you’re seeing post some screenshots.
The device is likely the 3.5mm headset port on the front of the PC. To confirm just plug in a headset /w mic into the port and open your Windows sound settings. There is a place in there to test the microphone.
If it is indeed the same device and you get an input spike with the headset disconnected, I’d take the lid off the PC and use a plastic object to tap around on the motherboard. That should help you locate the microphone if there is an internal one.
I have opened up the PC as per the above advice and used a soft anti static brush to possibly locate a noise spike as I was swiping over it. If you want to have a look and see if you would spot the mic, these are the photos:
Anyway, since I don’t see how to hide the photos within “spoiler” quotes, the mic is shown below:
Its the small shiny part on the corner of the board. It reads: MC32 R125
It is a surface soldered part which can make it difficult to remove. I feel a little bit better to know about it, but still uncomfortable to have an always on mic on my PC. Is there a way to know it’s not operational under Debian?
Well that’s creepy, I looked up a few product listings and non mention it.
Now could it be useful now its known about. Maybe for someone making a automated home things could be cool with their own self comtained system.
You should try contacting the manufacturer and see what they have to see about it.
Possibly even pressure them to add it to their product description.
That seems like a very odd and ineffective location for a microphone. Usually an internal mic like that is under a mesh grill or there is a hole in the plastic (clearly labeled “MIC”) right beside it. I bet it sounds awful if you try to use it for audio calls.
Anyways, check BIOS and see if there in an option to disable it. Most laptops will let you disable the internal MIC while keeping the headset jack active.
Now that’s just weird. I would contact the manufacturer about it, and put some electrical tape over it to muffle any input.
I was thinking it could have been for ambient audio levels to auto adjuest volume
Not a speaking mic as such but environmental, maybe. Could also be a noise canceling mic?
Not sure. All I can find is that it’s an Intel 495 chipset based motherboard and no indication of WHO actually made it. Looking at a few reviews of that Beelink unit, nobody seems to have mentioned an extra microphone showing up in the system.
Well that was interesting… just went down a rabbit hole trying to identify the type and manufacturer of the microphone. So these are called MEMS microphones and are commonly used in smartphones, tablets, smart home devices, and wearables. I couldn’t find the spec sheet for that particular model but I’m pretty sure it’s manufactured by CUI Devices. All the MEMS mics they sell are designed to operate within the frequency range of voices. Could be used for environmental but also perfectly usable for voice. :man_shrugging:
Okay. Last post and I promise to stop spamming this thread. Just found another Beelink model with a microphone hole and label in the exact same location as where OPs found his MIC. After seeing this I’m more inclined to say they forgot to include the hole in the plastics so they just pulled the feature from their specs list rather than retooling the factory mold. Just my 2 cents.
Interesting finds.
I actually destroyed the mic, cause I really am bothered by these kinds of things. Not the cleanest job, I couldn’t actually de-solder it and didn’t want to use a heatgun as it would destroy everything around. Did the job with a soldering iron. Sure enough, no noise detection is found Windows’ control panel, so that’s good enough.
