So my question to you is how do I get it to run in 64 bit? I checked my os it is a 64 bit version of windows 10. I have a Ryzen 3 2200g, 8gbs of ram.
How do you know everything runs in 32bit?
sorry for long reply. i checked task manger.
In parenthesis a program says (32 bit)? If so, see if there is a 64 bit version.
32-bit programs will run in 32-bit mode whether or not the OS is 32-bit or 64-bit.
This happens to every program under task manager?
happens to every program under task manager surrounded by parenthesis ( ) I ran the 64 bit version of War Thunder from the program files but it just started in 32 bit anyway
