My mistake. Thank you all for working with me on this.
Netstat only shows network connections coming from/leaving YOUR pc. Not your network. YOUR PC. So if donkey porn shows up as a connection to YOUR pc. well then, assumptions will be made.
FINNALLY SOMEONE KNOWS THE ACTUAL DEFINITION!!!
Hacking
Cracking
Social engeneering
Viruses
All seperate things. people don't understand. lol.
Even viruses arent viruses. Trojans, spyware, adware. THERE ARE SO MANY THINGS.
AND THINGS INSIDE OTHER THINGS.
Ya dont mind him , he likes to pick on people with bad grammar. Just be more careful about personal info and remember everything done with your computer points to you and not the user. Personally recommend having a guest computer with nothing more than the min reguirements to surf the net. Saves alot of hassle and you can wipe and install as often as needed.
Indeed I do.
FYI, that's not the "actual definition" but the original meaning/Stallman definition.
There are 2 posiblillities:
#1 Someone/Something can use your wifi. Change the passwords.
#2 Someone/Something got controll over a computer in your network. Use a tool like wireshark to find suspicious traffic. Lokate the source and do a clean reinstall.
edit: There is also no need for anitviruses, software firewalls and more than 1 hardware firewall (your router is a firewall) and other kind of snailoil.
Okay. Well I have changed all the passwords and upped the security. I will have to use wireshark if the problem occurs again.
ok just to put something strait here,
if you have some one on your wi fi and its wpa 2 psk. that means they did it with reaver,
wich also means they have the checksum pin for your router.
wich in turn means that whatever you change your password to now all they have to do is run reaver with the -p(your pin) option and your router will give them whatever you changed the password to in less than 4 seconds wether its 1 character or 100.
its broken. you have to turn off wps protected set up. thats what they re going through so turn it off THEN change password and all is good.
popeye
That's the same thing as saying "I don't live with my mother, my mother lives with me and my wife."
Please enable automatic spell check, or download a plugin that will do it for you, if you have a different browser.
Please don't post on a two month old thread, bashing spelling.
Hey guys after long time of research studying all the forum download all the bloody shits finally
discovered one successfull wifi hacker,So guys i decided share with you.Am not posting the video
proof because youtube is continuously removing video due to it mal practice of real working hack.How
ever you can download the file below.Thanksssssssssssssssss
http://bit.ly/OUIVGj
