Good day.
A question has arisen (stupid). Using the WinUSB program I created a multiboot flash drive. First (as in the instructions) I recorded Win10 64-bit, after Ubuntu16.04. Now there is a need to add Win10 32-bit there. Is it possible to add it there or do I need to completely format the flash drive and write it again in the order: Win10 32, Win10 64, Ubuntu?
If you want to create a multiboot flash drive it might be easier to use a tool like Ventoy.
Thanks for your answer, I’ll try it, I didn’t know about it
Yeah with Ventoy you can add multiple bootable iso´s to one drive.
You can boot from the flashdrive and you will get a ventoy menu,
in which you can select the OS you wish to install.
