Hey guys,
I’m looking for some opinions on multi monitor setups. I currently use my PC for productivity on windows (AutoCAD Civil 3D, Lightroom, Photoshop, Excel, All of the tabs in chrome)
My setup now has a single Acer 32in 4k monitor which is great and really like the screen real estate, color reproduction is good enough for what I do. I came from a dual 23in 1080P monitor setup which was a positive move. But I miss me some multi monitor setup goodness.
I want to add more but I have reservations about what to do.
I have come up with two paths in my mind:
- 32in 4k monitor (Horizontal) flanked by two 24in 1440p monitors on each side(Vertical)
- Dual 32in 4k Monitors (Horizontal)
0 voters
I get another 32in 4k monitor and put them side by side. Everything matches but I like having a center monitor as a “main” monitor then turn my head to the other monitors when I need. I know I can just set them up asymetrical with one in front of me and the other off to the side but I really like symmetry and it would not be the best with my desk setup.
have the 32in 4k monitor in the middle and get two 24in 1440P monitors and put them off to the sides vertically. I like this idea but I’m concerned with the difference in DPI (32in 4k=137ppi, 23.8in 1440p=123ppi) causing things to look too big or small between monitors. I would probably use display fusion to “split” the right monitor into two separate top/bottom snaps.
I am leaning towards option 2 but what do you guys think of the jump in DPI between the two sizes? Do you guys use a lot of vertical (portrait) orientated screens? How do you like it? What are your preferences with alignment between a Horizontal and vertically orientated monitor?
TLDR: for productivity what would you choose: dual 32in 4k monitor or one 32in 4k monitor flanked by two 24in 1440p monitors?
