SonWon
1
So I built a new PC with a great multi core CPU, CPU model doesn’t matter for the question. How do I find the core affinity for a multi core CPU?
If you must know, 2700X.
I plan to isolate (and likely pin the critical VMs) most of the cores for KVM VMs.
SonWon
4
Thank you much for teaching me how to fish!
SonWon
5
Matching USB devices to USB Controllers run this in a terminal window,
for usb_ctrl in (find /sys/bus/usb/devices/usb* -maxdepth 0 -type l); do pci_path="(dirname “(realpath "{usb_ctrl}”)")"; echo “Bus (cat "{usb_ctrl}/busnum”) --> $(basename pci_path) (IOMMU group (basename $(realpath pci_path/iommu_group)))"; lsusb -s "(cat “${usb_ctrl}/busnum”):"; echo; done
Source from here.
