it will not connect to the internet by cable, only by wireless, if i dissconnect the wireless im just not connected at all
all drivers are up to date
the lights are on on both ethernet ports (pc and net box)
i have this
but i installed both mobo disc's and nothing and i got msi live updater or somthing like that
well if it doesnt work at all, normaly if you inster the cd then you get a menu, where you can select the ehternet driver sata driver chipset driver sound driver etc. wenn you allready tried that, and the lan connection doesnt work at all, then you better contact the reseller about this problem. probably something wrong with it then..
