I have a strange issue with my computer. When I plug in an NVME drive into the NVME.2_3 connector I loose my internet connection. I’ve tried two different NVME drives and get the same result. Removing the drive returns the network connections to normal.
I’m running Proxmox 6.1. I believe this is a linux setup issue but am not sure how to troubleshoot/fix the issue.
When booted with the NVME drive in place, I can ping my host address and the return result is good. The output of ‘ip add’ shows the correct static address (of course because it’s manually set). But when I ping any LAN or WAN addresses I get 100% loss.
The output of lspci -v shows the two NIC’s I have are available.
Any pointers would be much appreciated!
Thanks
Andrew
