MSI MAG Z690 Edge DDR4 re-bar issues
Greetings!
I’m having issues with my two Intel Arc b60s I got. The first one works just fine, but the second one is not usable because it fails to map the memory space needed. I’ve been trying everything to get it to work with no luck, even resorted to ClaudeAI to see what it could do.
I tested the GPUS in an Asrock B650 PG Lightning motherboard and it just worked, no tinkering needed. I was suspecting it was because the second slot uses the chipset, instead of the CPU, but this voided that idea.
sudo dmesg | grep “xe”
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.17.0-22-generic root=/dev/mapper/ubuntu–vg-ubuntu–lv ro quiet splash xe.sriov_enable=0 pci=nosriov vt.h
andoff=7
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000095] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
[ 0.073335] Kernel command line: BOOT_IMAGE=/vmlinuz-6.17.0-22-generic root=/dev/mapper/ubuntu–vg-ubuntu–lv ro quiet splash xe.sriov_enable=0 pci=nosri
ov vt.handoff=7
[ 0.215997] … fixed-purpose events: 4
[ 0.005599] … fixed-purpose events: 3
0.448371\] pci 0000:00:1f.4: BAR 4 \[io 0**xe**fa0-0**xe**fbf
[ 0.529946] pci 0000:02:01.0: bridge window [mem 0x00000000-0x800ffffff 64bit pref] to [bus 03] requires relaxed alignment rules
[ 0.529952] pci 0000:08:01.0: bridge window [mem 0x00000000-0x800ffffff 64bit pref] to [bus 09] requires relaxed alignment rules
[ 0.530225] pci 0000:02:01.0: bridge window [mem 0x400000000-0x1818ffffff 64bit pref] to [bus 03] requires relaxed alignment rules
[ 0.530230] pci 0000:01:00.0: bridge window [mem 0x00000000-0x800ffffff 64bit pref] to [bus 02-04] requires relaxed alignment rules
[ 0.530235] pci 0000:08:01.0: bridge window [mem 0x400000000-0x1818ffffff 64bit pref] to [bus 09] requires relaxed alignment rules
[ 0.530240] pci 0000:07:00.0: bridge window [mem 0x00000000-0x800ffffff 64bit pref] to [bus 08-0a] requires relaxed alignment rules
[ 7.721355] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 7.788450] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFil
eIsExecutable=/usr/bin/ovs-vsctl).
[ 9.718789] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[ 11.519969] xe: unknown parameter ‘sriov_drivers_autoprobe’ ignored
[ 11.519973] xe: unknown parameter ‘enable_guc’ ignored
[ 11.519974] xe: unknown parameter ‘sriov_enable’ ignored
[ 11.519975] xe: unknown parameter ‘sriov_enable’ ignored
[ 11.556939] xe 0000:03:00.0: vgaarb: deactivate vga console
[ 11.557812] xe 0000:03:00.0: [drm] Running in SR-IOV PF mode
[ 11.558056] xe 0000:03:00.0: [drm] Found battlemage (device ID e211) discrete display version 14.01 stepping B0
[ 11.559587] xe 0000:03:00.0: [drm] VISIBLE VRAM: 0x0000006000000000, 0x0000000800000000
[ 11.559625] xe 0000:03:00.0: [drm] VRAM[0]: Actual physical size 0x0000000600000000, usable size exclude stolen 0x00000005fa000000, CPU accessible size 0
x00000005fa000000
11.559630\] **xe** 0000:03:00.0: \[drm\] VRAM\[0\]: DPA range: \[0x0000000000000000-600000000\], io range: \[0x0000006000000000-65fa000000
[ 11.559634] xe 0000:03:00.0: [drm] VRAM[0]: Actual physical size 0x0000000600000000, usable size exclude stolen 0x00000005fa000000, CPU accessible size 0
x00000005fa000000
11.559638\] **xe** 0000:03:00.0: \[drm\] VRAM\[0\]: DPA range: \[0x0000000000000000-600000000\], io range: \[0x0000006000000000-65fa000000
[ 11.665623] xe 0000:03:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 11.799722] xe 0000:03:00.0: [drm] Finished loading DMC firmware i915/bmg_dmc.bin (v2.6)
[ 11.805225] xe 0000:03:00.0: [drm] GT0: Using GuC firmware from xe/bmg_guc_70.bin version 70.60.0
[ 11.923211] xe 0000:03:00.0: [drm] GT0: ccs2 fused off
[ 11.923214] xe 0000:03:00.0: [drm] GT0: ccs3 fused off
[ 11.944642] xe 0000:03:00.0: [drm] GT1: Using GuC firmware from xe/bmg_guc_70.bin version 70.60.0
[ 12.032147] xe 0000:03:00.0: [drm] GT1: Using HuC firmware from xe/bmg_huc.bin version 8.2.10
[ 12.045016] xe 0000:03:00.0: [drm] GT1: vcs1 fused off
[ 12.045028] xe 0000:03:00.0: [drm] GT1: vcs3 fused off
[ 12.045032] xe 0000:03:00.0: [drm] GT1: vcs4 fused off
[ 12.045035] xe 0000:03:00.0: [drm] GT1: vcs5 fused off
[ 12.045038] xe 0000:03:00.0: [drm] GT1: vcs6 fused off
[ 12.045041] xe 0000:03:00.0: [drm] GT1: vcs7 fused off
[ 12.045044] xe 0000:03:00.0: [drm] GT1: vecs2 fused off
[ 12.045047] xe 0000:03:00.0: [drm] GT1: vecs3 fused off
[ 12.102600] xe 0000:03:00.0: [drm] Registered 4 planes with drm panic
[ 12.102620] [drm] Initialized xe 1.1.0 for 0000:03:00.0 on minor 1
[ 12.153819] fbcon: xedrmfb (fb0) is primary device
[ 12.153833] xe 0000:03:00.0: [drm] fb0: xedrmfb frame buffer device
[ 12.167574] xe 0000:03:00.0: [drm] Using mailbox commands for power limits
[ 12.168080] xe 0000:03:00.0: [drm] PL2 is supported on channel 0
[ 12.169796] xe 0000:09:00.0: [drm] Attempting to resize bar from 0MiB → 32768MiB
[ 12.169820] xe 0000:09:00.0: [drm] Failed to resize BAR2 to 32768M (-EBUSY). Consider enabling ‘Resizable BAR’ support in your BIOS
[ 12.169847] xe 0000:09:00.0: [drm] *ERROR* failed to map registers
[ 12.169860] xe 0000:09:00.0: probe with driver xe failed with error -5
[ 12.202311] Creating 4 MTD partitions on “xe.nvm.768”:
[ 12.202330] 0x000000000000-0x000000001000 : “xe.nvm.768.DESCRIPTOR”
[ 12.205810] 0x000000001000-0x00000054e000 : “xe.nvm.768.GSC”
[ 12.209697] 0x00000054e000-0x00000074e000 : “xe.nvm.768.OptionROM”
[ 12.214461] 0x00000074e000-0x00000075e000 : “xe.nvm.768.DAM”
I booted up Windows 11 to update the firmware and it’s working with rebar on both GPUs just fine. I booted back into Linux and it’s still not working.
Turn on Resizable BAR in BIOS, clear extra PCIe memory limits, and remove invalid xe kernel parameters to fix the second Arc B60 mapping failure.
