System: 9800X3D, Corsair Vengeance DDR5 6000MT/s CL28 EXPO, XFX Quicksilver RX 9070 XT, be quiet! Pure Power 13M 1000W (ATX 3.1), Samsung 990 EVO Plus 2TB. Arch Linux 6.18.9-arch1-2, KDE Plasma 6 Wayland. BIOS 7E62v2A48, AGESA PI 1.2.0.3g. System is rock solid otherwise.
WoL, restore on AC power loss, set to Power on or Last state, all do not work on this board, apparently. All I need is remote power-on. I’ve got a Wireguard VPN on a Pi, SSH works fine, I just cannot get the desktop to turn on without physically pressing the button. Spent days on this and I cant find any fault besides firmware. Hoping I’m wrong.
The onboard RTL8126 NIC reports PME support for D0 through D3cold. The hardware claims it can do this. Yet PME-Enable is never set during sleep transitions. The NIC link light dies the instant the system enters S3 or S5. No standby power to the NIC whatsoever, so obviously nothing gets through.
OS side everything should be in order. r8126 DKMS v10.016.00 loaded with s5wol=1 s0_magic_packet=1 disable_wol_support=0 because Realtek, for some reason, hides WoL behind undocumented module parameters. Wake-on: g confirmed and persists through suspend. PCI wakeup enabled in sysfs. BIOS has Resume By PCI-E Device enabled, Onboard LAN enabled, Network Stack enabled, ErP disabled. I have tested every permutation of Wake Up Event (BIOS/OS), Network Stack (on/off), and ErP (on/off). Tested WoL locally on the same subnet with both a Python script(Termux) and the Wake On Lan app(Android). NIC just has no power.
Now, wake up events aren’t all dead. A USB macropad on the BIOS USB port wakes the system from S3 just fine, the lights never turning off making me think that at least the USB always on works during S3 suspend. The board simply does not keep the NIC powered to use it.
Moved on to AC power recovery as a workaround with a smart plug, locally hosted of course. Set “Restore on AC Power Loss” to “Power On”. Clean shutdown, PSU off, wait, PSU on. Board does fuck all. Tried “Last State”. Same. Tried ErP both ways. Same. This is an ATX 3.1 PSU and this feature has worked since the 90s, don’t think 3.1 broke it.
So that’s three independent features that all rely on the firmware handling power states correctly, and all three are broken, I’m pretty sure. The hardware supports WoL. The driver configures it. The OS enables it. Macropad USB wake should prove the path can work. The PSU is compliant.
Two newer BIOS versions exist (7E62v2A4C and 7E62v2A50). Both only list “AGESA PI pre-1.3.0.0 updated” with no mention of power management fixes. I haven’t tested them because MSI doesn’t publish detailed changelogs and the last BIOS update on this board already broke my WiFi. Not testing my luck again.
Any tips are so damn welcome.
