Mouse issue
Hey guys i built a pc about a year ago, While i play games the mouse seems not smooth or studdery but is is very annoying and makes me not want to play any pc games.
i keep all drivers up to date, i have done the markc  mouse accel fix, iv tried all kinds of dpi settings via mouse and in game settings, i have tried several mice and pads nothing seems to fix my issue any fix for this or is it something i just have to deal with.pc specs Asrock z77 extreme 6 motherboard intel core i5-2500k processor  g-skill 8 gig 1866 ram western digital caviar green 500gb hdd Rosewill hive 750 watt power supply  nvidia gtx 480 gpu arctic silver cooler thermaltake a31 case razer death adder 3.5g infer red mouse windows 7 home premium 64bit
have you tried different usb ports or reinstalled your os?
maybe it's the surface you use your mouse on? if there's any kind of gloss could throw off the optics.
i have re installed windows several times and tried all usb ports on my pc no fix.
my current mouse pad is a steel series gaming Matt pure black but i have tried other surfaces and i see no change but i strongly appreciate the suggestions any other ones.
Its just very frustrating because the games run soo well on my pc but because of mouse issues i dont want to play them but the stange thing is if i use xbox controller it works perfectly no jittery movements.
maybe your mouse is dying? loose cable? is the laser or optic flickering?
maybe dirt somewhere?
https://teksyndicate.com/forum/build-pc/new-pc-mouse-issues/157624
You posted this up twice.
nope can rule those out as well the mouse is new been jittery out of the box, i bought it hoping it would fix my issue but i just wasted more money.
After goggling the  issue it seem lots of people are having similar issues most of them are saying it occurs after the upgrade to a 64 bit OS, i could re install 32 bit version but i feel i will just loose all my info for nothing so ill will keep it as last resort.
yea i posted it twice i first posted in build a pc but figured it may fit pc gaming better sorry im new to forums in general.
https://teksyndicate.com/news/2013/10/23/windows-81-gaming-mouse-lag-fix-ms-please-permanently-fix
this helps my issue a lot but not completely at least i can bare to play now thanks..
my problem is still here doe sent really help in any other game and now bf4 is out i would love to play smoothly any more suggestions?
mate don't make 2 threads within an hour of each other then keep bumping them at the same time.
no offence bro if your not here to help don't post. Yea i got two  one in gaming and one in build a pc so people can see it and possibly help me cause there is nothing more frustrating than building a 1500 dollar pc and cant game on it..
http://www.youtube.com/watch?v=9SyvJcCwQ2w
seems im not the only one with this problem.
