Hi,
I want to run Mountain Lion in VirtualBox so I can use MAC only apps. Guides that I have read only give instructions on Intel CPUs. I would like to know if this is possible and if so how you would do it.
Thanks
Hi,
Thanks
This does NOT work on Virtualbox, from my experiance.
You need VM-ware workstation.
You can download ready to go vmware images. with both a intel and an AMD kernel patch including instructions.
Grtz Angel ☺
hackintoshing on amd is like trying to put a stock intel cooler in that fx350
What is your point with this post?
What you need to do is
- Download VMWare (As this requires VMWare and will not work with virtualbox)
-go to http://www.souldevteam.net/blog/2013/03/22/os-x-mountain-lion-10-8-3-vmware-image/ to Download a VMWare image of OS X 10.8.3 with the AMD patch
-watch the YouTube video embedded into the post for step-by-step instructions on how to install the VM as its a bit different from a normal VM as your are using a VMWare image not an ISO
Hope it works out well for you :)
Good luck! AMD hackintoshing can be some pretty difficult stuff. Sometimes it just flat out will not work, so be prepared for that. However, if you are successful, please post the results. AMD hackintoshing to me is pretty entertaining.
Please read date of last post before posting @Shyamez
