so, i bought a Gigabyte GA-F2A68HM-H motherboard and AMD Athlon X4 860K. i tried to use the motherboards HDMI port to test if they work, since i won't be able get a graphics card for another month or 2. Both of my tvs seem to recognize that its connected but nothing showing up on ether of tvs.
The 860k doesn't have an iGPU, did you like post on build a PC before buying it?
Also what RAM did you buy with it?
You'll either want to return it for the A8 7600 for $80 dollars
https://pcpartpicker.com/part/amd-cpu-ad7600ybjabox
Or the 7850k for $120, nothing in between is really worth it
https://pcpartpicker.com/part/amd-cpu-ad785kxbjabox
oooh ok. 2X2 will upgrade later . i'll check out cpus. thanks
No I meant the speed of your RAM, because you may also want to throw that in the return box to get 2400mhz memory to get the most out of your APU
1333mhz
Ya, I'd go ahead and toss that in the return box as well, you want 2400mhz memory with an APU
