Motherboard installation. Help!
I am confused on how to install a micro atx motherboard into my thermaltake commander MS-I it is not like other installations I have seen. Any help would be appreciated .
I do not personally have this case but I would suggest that you will need to put the motherboard standoffs into the corresponding holes for the motherboard.
the thing is there are no real holes for standoffs. There are some sort of raised holes for screws but idk if i want to use those as not to damage the motherboard
Can you snap a picture of the inside of your case Ryan?
yep
The pictures are not working Ryan, did you get them hosted?
http://www.oxperu.pe/case-thermaltake-commander-ms-i-id.html
link was the best I could do you can zoom in kinda on the pic of the inside
