My friend is considering getting a 700-800USD system for gaming, he might do some light streaming and recording. I settled him on this build for now.
Just wondering what you guys think of the Mobo, it seem like a pretty good board to me.
is he tempting to overclock?
if so then stay away from gigabyte AM3+ boards, they have realy well known overheating issues on the mosfets vrm´s and northbridge chip, wenn try overclocking. i am totaly not a fan of gigabyte am3+ boards i will make a list of boards is personaly recommend for that powerhungry FX8350.
Take one of thease boards listed.
About the GPU Try to pickup a Radeon 7950 you can get them for just a few bucks more, but its realy worth it. like the gigabyte 7950 windforce. or the Msi 7950 OC. orthe sapphire 7950.
grtz Angel ☺
Anything that's under 150 USD??? All the boards you mentioned are a bit pricey, any better value boards you'd suggest?
The Asus M5A99FX Pro should be under $150
Yeah, it just caught my eye, looks like a pretty decent board. Definitely not plagued by the VRM issues of the UD3.
yes the Asus M5A99Fx Pro R2.0 is a good choice. also not a bad choice would be the Asrock 990FX Extreme 4.
But i would recommend the Asus M5A99FX pro R2.0 Pistol uses this board in her rig. its capable of doing standard overclocks to 4.6ghz without any pain.
I run Gigabyte Motherboards and have never had an overheating problem. But I don't overclock unless necessary or for experimentation...
I think the Asus would be the better choice of the two, it is a tad cheaper and looks like a bit more solid of a board.
