I finally decided to try linux and I'm starting to like it. But when I started playing I couldn't hear my gpu fans to speed up at all so I would like to know how I can control them and monitor GPU temperature.
I'm using Ubuntu Gnome 15.04 and proprietary drivers. GPU ASUS R9 280X MOBO ASUS Z97-A
I tried Psensor for temp monitoring but it doesn't show my GPU temp.
You can try running sudo detect-sensors, which will look for any sensor related kernel modules which have not been loaded. Or else you may have to install the proprietary AMD driver which should have the correct firmware for your sensors - located in the firmware-linux-nonfree package.
Make sure you downloaded psensor through the Ubuntu software centre as well, otherwise you will be missing dependencies such as lm-sensors
Sorry, sudo sensors-detect. Watch for the lines it wishes to add to /etc/modules at the end of the program. Most hwmonitoring software on Linux uses the lm-sensors libraries so they will all have the same issue unfortunately. If lm-sensors still does not detect the temp sensors(s) then you can try manually loading the kernel module
Sorry, yes I can understand how my post would have been interpreted that way, but I was asking OP to post the return of lspci - evidently poorly worded
I thought AMD may have done it directly through PCI but it appears they don't. So sensors-detect was fruitless? Have you tried using the AMD driver config? Something like aticonfig --adapter=all --odgt
