Monitor recommendation 32 inch 1440p gaming
Hello fellow Level1techs
after this christmas I am searching for a 300-400€ 32 inch 1440p monitor. Any recommendations?
Will use it primarly for gaming and browsing so dont really care so much about true color etc.
Thank you
What's your PC hardware?
I don't think anyone really makes 32" 1440p
as for other high end options, you really have 2 choices, 4k 60hz, or 1440p 144hz, better to invest in one of those, you'd never really need to replace either
there's 4k IPS free-sync 27" here for about 400 EU
https://de.pcpartpicker.com/product/yfx9TW/lg-27ud58-b-270-60hz-monitor-27ud58-b
the 1440p 144hz option is over budget and TN
https://de.pcpartpicker.com/product/spbkcf/acer-monitor-umhg0ee001
I guess there's one for like 500 EU, and it's TN, don't buy it man
https://de.pcpartpicker.com/product/sgDwrH/benq-monitor-bl3200pt
Also try to look for this pixio display, 1440p 144hz IPS with free-sync
Idk if there is a 32 inch version but they should. QNIX makes a great 27 inch 1440p monitor that can OC to 100hz I've had it for a while works great. Only has 1 dual link dvi port though which sucks.
I have an I5 3570k-16GB DDR3-RX480 8Gb ref design.
Current Monitors are two asus ve278 Q
there is a crossover 32S I was thinking about reviewing. Its not overclocked out of the box, but its 32", premium panel, 1440p. Its the same price as a 27" 1440p 144hz panel though, so its hard to pick between them. slightly favor the 1440p/144hz
Then outside of korean monitors I'd go for the Acer XG270HU probably, since it's 144hz and free-sync
just look up some reviews
I could get a could deal for the Asus VA32AQ. Anyone had expierence with it?
A VA monitor from Asus? I would bet that it would be a fine choice.
i am currently running two asus ve278 Q. Had not fault with them so far.
so I nearly finished the build.
Still have to do the color calibration etc. but so far I like it.
sorry for potato qualitiy
