Hello everyone,
my new LG monitor came with a comically short cable that connects it to it’s power supply and I was wondering if it was safe to make a barrel jack cable extension to plug into my monitor in order to avoid having to use a traditional power cord extension, which is bulky.
Thanks!
https://www.ebay.com/itm/2-1mm-female-male-barrel-jack-extension-cable-1-5m-5-ft-Arduino-CCTV-Camera/181728009779 Your problem will be getting the correct size connector.
Also keep in mind that the longer the cable, the greater the voltage drop is.
Thanks for the answer.
The barrel connector is not a problem. What I was worried most were issues with voltage. Maybe I can safely do it with a low gauge wire to reduce the voltage drop.
