My hanns g HW191D stopped showing the native resolution (1440x900), currently on my windows 7 the highest i can go is 1024x768, how do i get my native 1440 back? currently i'm using the dvi cable on my pc (xbox 360 for vga)
the monitor is showing as generic non-pnp instead of the manufacturers name on the device list
i installed the recent motherboard+graphics drivers.. that didn't work
i reinstalled fresh copy of windows.. that didn't work
i changed the dvi cable.. that didn't work
i added custom resolution option on my nvidia settings but that just zooms the monitor very badly
i think this happened while i was switching modes between xbox 360 and pc while xbox was booting a game up
this happened before but i cant remember how i fixed the problem, also.. it can't be the drivers since windows picked the monitor up when it was running fine. i looked around for EDID.. maybe that got corrupted communicating between the monitor and pc
note: i switched to vga cable on temp basis.. had 1440x900 showing up
Alright so vga works but dvi doesnt... have you tried only having the dvi plugged in with the computer. Or just having the vga plugged in with the xbox run the xbox for a bit then turn it all off then plug dvi back in and switch. Just a bunch of variations could potentially fix it.... This does seem quite weird to happen though.
What type of Video card are you using? With most of the software you can force a resolution even if the computer doesn't detect it. Also if you can't do it that way you can make and load your own monitor driver.
