Monitor and SLI Compatibility Question
Greetings, I have a question concerning my current monitor arrangement. I'm using 4 monitors with a multi GPU configuration, and with this SLI is disabled. The configuration of the GPU outputs are x2 DVI on the first card and x1 DVI, x1 HDMI one the second card. My question is, if I populate all of the graphic outputs on the first GPU would I be able to run SLI. I've heard that it is possible to run SLI with four displays but maybe I'm thinking about crossfire. The way I would run the last input would be with a DVI to Display port dongle. Feel free to ask any questions. Thanks in advance and Cheers.
no harm in trying.
