I have DPS475CB A POWER SUPPLY from my xw4600 and found out that it doesn’t work with h81m s2pv motherboard and needs some modding can anyone help me with it
Also i noticed that the 24pin is missing 3pins
that’s a 475w power supply are you sure messing with it is worth it?
be sure to use a multimeter so you don’t blow up your components
