Modding an H100 for no good reason
The case, not made to fit H100, bummer
Warranty void
I bent and welded this at work after removing all the surface rust
Bought some poly-carbonate and made some really bad cuts
Then I got hungry so work stopped
I had to slather it in epoxy to fill the gaps
I might finish it up within the week or next several months depending on my motivation, feel free to point and laugh or tell me where I went totally wrong.
What exactly are you modding it to? I'm guessing that's a res, since you tapped it with what I assume is a G1/4" thread (11.8mm bit, right?), and you've removed the tubing...
i was just thinking about this the other day
Indeed I am, sorry for being scarce on the details, I am going to throw the rad and res in the box I made. Luckily my case has grommets for the tubes to go through the back.
If I didn't have a few screws loose I would have just gone custom loop from the get go but that wouldn't be half as fun.
i figured it's relatively cheap to start off, and should i choose to do a full loop in the future i already have a pump, cpu block, and rad
Why not just drill some mounting holes in the top? Case looks physically large enough for a slim 120.2.
right? i always wanted to mod a AIO after i saw a thread on overclock.net about it.
I just really wanted to build a reservoir and at the pace I work on little projects like this I didn't feel like have my PC apart for that long.
whats for dinner and wash your feet.
+1 what did you have for dinner?
That is cream of potato with extra onion, bacon and Dumplings.
and these don't wash off
Both awesome, and disturbing. That's neat!
i perfer to show my love of soul eater on a shirt, but to each their own
hahaha that's what they reminded me of too.
Your soul eater's images are real close to your sole's, be careful..
Either way I've got more Grinding and cutting to do on the rad box and the res should be fully cured tomorrow so I might leak test that
