Recently my desktop has been having weird USB problems.
Rig: http://pcpartpicker.com/p/2iyxk
Whenever I'm just using the computer, I'll hear the Windows 7 chime that notifies when you've unplugged a device, and my mouse, or keyboard, or nothing I notice stops working for about 3-5s. It's starting to bug me because it happens a couple times a day, and it doesn't help my gaming.
I do not hear the Win7 chime (the device plug-in chime) after the windows 7 device disconnect chime. I've tested various usb 2.0 on the back of my motherboard, but it still happens.
Is there a way to figure out what's going on?
Could be a PSU issue... blown or leaking capacitors could cause issues like that, and XFX uses chinese caps...
I'd try buying an externally powered USB hub and see if that fixes the problem... and mentally note that the PSU may need to be replaced in the future...
Sidenote... how does that Mini ITX board do at overclocking? (I assume you're overclocking cause it's liquid cooled)
I haven't bothered overclocking my i5 yet. I usually only overclock when the game needs it.
I'll try a powered USB hub and see if that works.
//edit
Says here XFX Core Ed. PRO 550W PSU uses solid japanese caps, rated @ 105c
http://www.kitguru.net/components/power-supplies/zardon/xfx-pro-series-450w-and-550w-power-supply-review/5/
Confused :S
hmm... why the watercooling if you're not overclocking? seems excessive :P
wasn't dissing your PSU by the way... XFX is a off brand Seasonic basically and they use the nice chinese caps but they're still chinese caps and I don't trust anything chinese (even though I can get away from everything I own being made by them) f'in chinese labor laws stealing american company's jobs :(
Because the stock Intel cooler isn't fancy. I picked up my Seidon 120V for $40 after a MIR(too cheap not to buy lol). It also allows me to overclock whenever I want, so I don't have to wait for a new cooler to arrive.
XFX's website also states 105c Japanese caps, but who really knows where they come from :P?
I believe ya... seems I read different somewhere *scratches head* ... irregardless... most of the time you get sign on sign off issues with plugins people point the finger at the mobo and it's the psu... i assume you check all your cabling to make sure it's tight and all that... but that's my best guess... i will say if the powered usb doesn't fix it, it's the mobo... so that's a good way of identifying the culprit regardless... and powered external usb's aren't gonna break your bank or anything
