I'm looking for a ATX mobo that can run a 1440p screen via DVI-D.. I'm having trouble looking for one. I'm planning on using the i5 4670k's HD 4600 Graphics to run the 1440 monitor.
Is it even possible to run 1440p from DVI-D off motherboard?
- the MSI Z87G45 DVI-D maxes at 1920*1200 I think.
Or do you have to run the monitor off a graphic card?
The cheap korean 1440p screens only come with DVI-D... but i could get the more expensive one with displayport instead..
You need a dual link DVI connector. Dual link DVI supports up to 2560X1600. Single Link only supports up to 1920X1200. The MSI board has a dual link connector so you should be fine.
The integrated graphics shouldn't have any problem powering the display so long as you aren't trying to game or something on it.
Mm yes I didn't think of that. A dual link jack that is electrically single link. Seems a bit silly to me though that it would be like that on a desktop motherboard. I tried looking on MSI's site but they don't list it.
if you already have the board you could run it off an hdmi adapter with a lower refresh rate, i don't know whether or not it would make a difference for your uses
otherwise anything with a dual link dvi or displayport will work
Gaming + work, I heard the 4600 can run up to 4k... I'm also going to get the gtx770, but I think running the monitor while gaming will hinder the gtx770's performance.
Thats why I'm trying to run it off the 4600 instead.
Also please note that if you have a graphics card you arent going to be using the on board graphics. It doesnt work like that. You plug the screen into the graphics card and thats it. plugging it into the onboard graphics will mean you arent using your GTX 770 or whatever card you get
