Any recommendations on motherboard for Ryzen 3900x with good iommu groupings, so I could add a 2nd gpu and set up pcie passthrough?
I’ve thought I’d try to set pcie passthrough on my workstation with b550 moba (asrock) - but then I’ve checked iommu and it’s brutal… I’ve read a couple of posts - but most are pretty old (yeah, I know - this hardware is nowhere near to “new” status ) and a bit confusing (and also with lots of notes like - “wait till new bios is released”).
The Ryzen 3900X is recommended to be paired with a B450/X470 motherboard. For those with ample budget, the X570 option provides PCIe 4.0 support and superior power delivery.
thx! I got a pretty nice deal on Gigabyte Aorus Pro X570. And that solved it for me - the iommu groupings on that are pretty sensible and I’ve been able to set up pcie passthrough and LookingGlass on it.
The only small hurdle was finding virtualization options (svm) in the bios - it was pretty unintuitive to me to look for those in the tweaks section (especially considering iommu options are somewhere else).
