Recommendations and Advice.
Currently using MKV to backup my blue ray and dvd collections. Just using it to backup the content raw to its default save types.
Being an Audio and Videophile, I am wanting to keep the best quality possible of these backups during the encoding process, sticking with H264.
I am aware cpu gives the best compression, not necessarily the best quality, and it is slow. Using handbrake above 6 cores has diminishing returns, lest you are using Xeon/Epyc/Threadripper cores above 16.
I have looked into using GPU encoding with AMD/INTEL/NVIDIA and seen various stats on the times, size and speed.
Currently, I have various AMD graphics cards up to the RX 6600, an old RTX 1650 super.
If keeping them uncompressed gives me the highest 1 to 1 quality, and the only way to reduce size is to remove certain audio and subtitle encodings, then I can accept that, and just increase my NAS storage accordingly. Which this equates to roughly 500TB of storage down from 800.
If anyone has used GPU encoding with best quality settings, while still maintaining decent compressions speed, please post GPU type and best settings used.
I know AMD tends to lag in the quality arena (but I am a loyalist) I donāt have a problem buying an Intel or Nvidia since I have a machine setup strictly for backing up and encoding, would prefer not to though.
So far I have experimented with Akira on both DVD and Blue ray using both CPU at various numbered cores (Hand brake and GPU encoding at various settings).
So far nothing has really given that (awesome) feeling. It is an OCD thing for me, however I am able to see the difference in the visual compression and hear the difference in audio compression from lossless.
Appreciate the input and opinions.
