Minisforum N5/Air/Pro OCuLink NVMe?
Hi gang, I have a Minisforum N5 Air and am considering downsizing my BigNAS™ (with 8x HDD, 2x U.2 SSD, 3x M.2, 1x 2.5” SATA SSD) to this SmallNAS™ with room for 5x HDD, 3x M.2 by default.
I’m trying to cram as much storage into this thing as possible, and I know that it doesn’t support PCIe bifurcation so another addition is a simple PCIe to 1x M.2 NVMe adapter for one additional drive. But what about using the OCuLink port for a fifth M.2 NVMe drive?
Basically, what do I need to buy to get an M.2 2280 NVMe SSD to work with the OCuLink port on the back of the Minisforum N5/Air/Pro? I’m finding conflicting reports of whether I should get a direct OCuLink to M.2 NVMe adapter (but what about power, does the OCuLink port supply it?), or an OCuLink to U.2 adapter that needs a separate SATA power input (but where would I get SATA power from on the N5?).
Ok, apparently this used to be a thing but was either never actually produced or is now discontinued? Alas, would’ve perfect for my use case… AOOSTAR launches a 4-bay SSD enclosure with OCuLink and USB4 ports - Liliputing
