What do we put on it for home use? Opensense, xcpng? Proxmox? VMs… Clean slate
Try playing with vPro. If you can get it working it’s effectively as good as kvm over ip. Probably not going to get “display output” but for a headless appliance what is there to output…
That might be a little above my paygrade today. Thabks for the sugesstion. At the moment i need to get a VM of windows running for a workstation hopefully on the MS01 using its hardware without another machine to log in…
For home use on your Minisforum MS0,1 Proxmox VE allows you to run virtual machine on your hardware
