or a arctic freezer III to that mobo , im ok with having a open case like that in my rack
iv got a custom rack shelf that mounts a twin 5.25in bay an rad for an old open frame build that i once had , that was to big but if i could use this with my 280mm aio an burner an 5.25in bay raid adapter that would be great as id
get far better horse power in a smaller footprint then my current setup.
For the Minisforum MS-A1 custom build, you might wanna start by checking the power supply requirements and ensure compatibility with your chosen components. Also, look into the thermal management to avoid overheating issues.
This is what i did with my MS01. I think theyre the same with different processors upon cursory inspection. I have mobo dims and hole spacing for mine.
