Minisforum-bd770i build an config info needed?
i need some help , info , an advice
question 1
is the BD770i ITX Motherboard an AMD Ryzen 7 7745HX with
Native PCIe® Lanes (Total/Usable) 28 enough to handle this build’s drives an network card at
full bandwidth for the nvme ssd , the 10gbit network card , an the 6 2.5in ssd in raid o config
this plan with this build is to use as a rip/converter rig for 4k & bd discs from the disc drive
an other vid , audio , an pic files vi my 10gbit network switch an 3 2.5gbit connected pc’s ?
the overall idea is the reduce the work-load an bottle neck from the main pc’s for all
the stated tasks to the mini-forums BD770i build an then have the batch rip an converts only
temporarily stored on the 3tb (6x500gb ssd raid 0 config) before bulk file off-load
to a 60tb custom nas
question 2
is ther an os an or app combo that can be used on the BD770i ITX to do this ?
question 3
is this hdplex-500​w-gan-aio
enough to power this rig
my pack n rip build
an will custom cables from cablemods work with this psu ?
