Minecraft Server Setup Help
Hey guys i want to start a small minecraft server just for me and my brother. So we can play from different computers. Does anybody know how to setup a small server like this and what internet speeds do you need up/down. Thanks for anyone who helps.i also heard of bukkit and tekkit. We live in the same hosue
Consider just using the innate "Open to LAN" option. I assume you are using the same network if in the same house? If not you can set up port forwarding or use tungle or something to create a virtual lan and do that.
http://minecraft.gamepedia.com/Multiplayer#Local_area_network
Otherwise a bukkit server should be reasonably easy to set up, depends if you want mods or not as to how difficult.
Tekkit servers do require quite a bit more power behind them to run smoothly. I would recommend having a dedicated server if you wanted to run this.
Alright, first off, as you're both in the same house (and on the same network), your net bandwidth won't matter much; your local speeds are more than sufficient for a Minecraft server.
We're gonna go ahead and jump straight to Bukkit, since you'll probably come to love the plugins you'll eventually find.
Go here and follow the directions for your platform. Note that when it has you type out the 'java -Xmx1024M' bit, change 1024 to how much RAM you want to allocate to the server, in megabytes. I usually give it 4096 (4GB of RAM). Something you may want to note is that it can't give it more than 1.5GB or 2GB of RAM if you aren't running 64-bit Java.
Anyway, it'll be like this: "java -Xmx6144M -jar craftbukkit.jar -o true". If you're curious, the '-o true' bit at the end tells the server to run in online mode, which will check to see if your Minecraft account is legitimate or not. In most cases, you'll just want to leave it alone.
Once you've set it up according to the directions on that site, you can connect (via localhost if you're hosting on your own machine. For your brother, he'll need to connect via internal IP address. Check here if you need help finding that), OP yourself (in the console window that will open up, type in "op your_minecraft_name" while you're connected to the server, and you'll be able to run commands and otherwise control the server from within Minecraft. OP = operator.
If you're interested, I can make you a little tutorial on Bukkit plugins.
Thanks for your help and yes i would appreciate the plugins also what type of internet do i need since i live in south texas and our upload suck i have 50 download and 2 upload so do you think that is enough
Again, your internet doesn't make a difference if you're on LAN.
mcMMO: adds skills and special abilities. As you mine/chop wood/fight things/etc, you level up skills and make those tasks more efficient.
ExtraHardMode: Adds some realism and extra difficulty to the game.
VoxelSniper: For creative building, it's a very powerful tool. It's hard to explain; just look up a video on it.
WorldEdit: Same as above.
DynMap: Provides an interactive map that shows the worlds on your servers.
Those are some to try out.
