The background:
- I needed to move this from a VM to a physical box. I decided just to image the new box with a fresh server install and to recreate my MDT setup. At first the box was named GJRDeployment2. I installed MDT and tested working. I then took the VM offline and changed the name of the box from GJRDeployment2 to GJRDeployment. I went through and changed all the share names that I new about to reflect the change. I even deleted the boot folder and updated the deploymentshare to recreate the Light PE file.
The issue:
- Despite changing the share name in all the places I thought it would be, I still get this error message:
As u can see, it is still trying to connect to GJRDeployment2. I checked the DNS server where and GJRdeployment2 is no longer listed.
I did noticed my bootstrap.ini had the error. But I fixed it and then updated my deployment. I just tried it again and I am still having the same error of it trying to connect to the old share. Do I have to delete the control folder too and then update?
