Hi,
I’ve been trying to use looking glass without success.
Every time I boot my guest vm I see in the driver manager 2 graphics cards:
- Microsoft Basic Display Adapter
- NVIDIA GeForce GTX 3060 laptop GPU
I tried to disable or uninstall the basic driver but it reappear every start up.
The host service gives this error: “Not using unsupported adapter: Microsoft Basic Render Driver”.
How do I stop this basic driver from interfering?
I attached the host log and the virt manager XML configuration.
Thank you!
[I] 373209073 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [W] 373210026 platform.c:500 | boostPriority | Failed to set realtime GPU priority. [I] 373210869 platform.c:501 | boostPriority | This is not a failure, please do not report this as an issue. [I] 373211875 platform.c:502 | boostPriority | To fix this, install and run the Looking Glass host as a service. [I] 373212909 platform.c:503 | boostPriority | looking-glass-host.exe InstallService [I] 373213606 app.c:771 | app_main | Looking Glass Host (B6) [I] 373214013 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 373214426 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 373215748 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 373218828 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 373219177 app.c:789 | app_main | IVSHMEM Address : 0x2AE0000 [I] 373219524 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 373219856 app.c:791 | app_main | KVMFR Version : 19 [I] 373220177 app.c:809 | app_main | Trying : DXGI [I] 373222728 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 373223137 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 373223496 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 373223818 app.c:809 | app_main | Trying : NVFBC [I] 373229036 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 373235157 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 373235567 app.c:829 | app_main | Failed to find a supported capture interface [I] 373236969 app.c:982 | app_main | Host application exited [I] 9384193 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 9384885 app.c:771 | app_main | Looking Glass Host (B6) [I] 9385250 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 9385603 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 9386634 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 9389185 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 9389489 app.c:789 | app_main | IVSHMEM Address : 0x26D0000 [I] 9389755 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 9390038 app.c:791 | app_main | KVMFR Version : 19 [I] 9390280 app.c:809 | app_main | Trying : DXGI [I] 9409598 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 9410053 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 9410468 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 9410833 app.c:809 | app_main | Trying : NVFBC [I] 9418934 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 9425199 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 9425583 app.c:829 | app_main | Failed to find a supported capture interface [I] 9428285 app.c:982 | app_main | Host application exited [I] 10523326 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 10523689 app.c:771 | app_main | Looking Glass Host (B6) [I] 10524037 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 10524394 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 10525395 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 10528111 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 10528415 app.c:789 | app_main | IVSHMEM Address : 0x2790000 [I] 10528693 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 10528991 app.c:791 | app_main | KVMFR Version : 19 [I] 10529239 app.c:809 | app_main | Trying : DXGI [I] 10531716 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 10532142 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 10532521 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 10532822 app.c:809 | app_main | Trying : NVFBC [I] 10538257 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 10543478 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 10543776 app.c:829 | app_main | Failed to find a supported capture interface [I] 10545987 app.c:982 | app_main | Host application exited [I] 12600869 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 12601269 app.c:771 | app_main | Looking Glass Host (B6) [I] 12601587 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 12601933 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 12603014 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 12605560 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 12605817 app.c:789 | app_main | IVSHMEM Address : 0x2850000 [I] 12606111 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 12606371 app.c:791 | app_main | KVMFR Version : 19 [I] 12606646 app.c:809 | app_main | Trying : DXGI [I] 12608608 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 12609024 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 12609364 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 12609693 app.c:809 | app_main | Trying : NVFBC [I] 12614515 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 12619875 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 12620313 app.c:829 | app_main | Failed to find a supported capture interface [I] 12623542 app.c:982 | app_main | Host application exited [I] 16638201 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 16638618 app.c:771 | app_main | Looking Glass Host (B6) [I] 16638941 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 16639266 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 16640281 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 16642780 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 16643048 app.c:789 | app_main | IVSHMEM Address : 0x26E0000 [I] 16643314 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 16643573 app.c:791 | app_main | KVMFR Version : 19 [I] 16643819 app.c:809 | app_main | Trying : DXGI [I] 16645830 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 16646216 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 16646561 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 16646851 app.c:809 | app_main | Trying : NVFBC [I] 16651724 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 16656732 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 16657088 app.c:829 | app_main | Failed to find a supported capture interface [I] 16658711 app.c:982 | app_main | Host application exited [I] 24765335 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 24765721 app.c:771 | app_main | Looking Glass Host (B6) [I] 24766031 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 24766389 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 24767838 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 24770605 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 24770862 app.c:789 | app_main | IVSHMEM Address : 0x2950000 [I] 24771150 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 24771480 app.c:791 | app_main | KVMFR Version : 19 [I] 24771773 app.c:809 | app_main | Trying : DXGI [I] 24804773 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 24805167 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 24805537 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 24805867 app.c:809 | app_main | Trying : NVFBC [I] 24826156 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 24831554 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 24832085 app.c:829 | app_main | Failed to find a supported capture interface [I] 24833898 app.c:982 | app_main | Host application exited [I] 40864461 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 40864864 app.c:771 | app_main | Looking Glass Host (B6) [I] 40865181 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 40865527 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 40866467 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 40869021 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 40869317 app.c:789 | app_main | IVSHMEM Address : 0x2870000 [I] 40869611 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 40869868 app.c:791 | app_main | KVMFR Version : 19 [I] 40870155 app.c:809 | app_main | Trying : DXGI [I] 40872271 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 40872689 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 40873028 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 40873354 app.c:809 | app_main | Trying : NVFBC [I] 40879038 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 40885114 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 40885447 app.c:829 | app_main | Failed to find a supported capture interface [I] 40886822 app.c:982 | app_main | Host application exited [I] 7748864 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 7749519 app.c:771 | app_main | Looking Glass Host (B6) [I] 7749858 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 7750208 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 7751433 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 7754074 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 7754341 app.c:789 | app_main | IVSHMEM Address : 0x2710000 [I] 7754601 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 7754859 app.c:791 | app_main | KVMFR Version : 19 [I] 7755103 app.c:809 | app_main | Trying : DXGI [I] 7782069 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 7782583 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 7782923 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 7783289 app.c:809 | app_main | Trying : NVFBC [I] 7790187 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 9896316 app.c:829 | app_main | Failed to find a supported capture interface [I] 9898189 app.c:982 | app_main | Host application exited [I] 10961321 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 10961726 app.c:771 | app_main | Looking Glass Host (B6) [I] 10962004 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 10962351 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 10963331 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 10966410 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 10966788 app.c:789 | app_main | IVSHMEM Address : 0x2770000 [I] 10967105 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 10967456 app.c:791 | app_main | KVMFR Version : 19 [I] 10967735 app.c:809 | app_main | Trying : DXGI [I] 10973545 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 10974000 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 10974383 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 10974713 app.c:809 | app_main | Trying : NVFBC [I] 10979497 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 12986492 app.c:829 | app_main | Failed to find a supported capture interface [I] 12988836 app.c:982 | app_main | Host application exited [I] 15060081 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 15060480 app.c:771 | app_main | Looking Glass Host (B6) [I] 15060831 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 15061137 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 15062290 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 15065257 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 15065578 app.c:789 | app_main | IVSHMEM Address : 0x27D0000 [I] 15065901 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 15066223 app.c:791 | app_main | KVMFR Version : 19 [I] 15066481 app.c:809 | app_main | Trying : DXGI [I] 15069366 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 15069761 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 15070096 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 15070397 app.c:809 | app_main | Trying : NVFBC [I] 15074604 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 17080399 app.c:829 | app_main | Failed to find a supported capture interface [I] 17082018 app.c:982 | app_main | Host application exited [I] 21295943 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 21296366 app.c:771 | app_main | Looking Glass Host (B6) [I] 21296647 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 21297012 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 21298073 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 21300685 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 21300977 app.c:789 | app_main | IVSHMEM Address : 0x2890000 [I] 21301230 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 21301512 app.c:791 | app_main | KVMFR Version : 19 [I] 21301784 app.c:809 | app_main | Trying : DXGI [I] 21327686 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 21328178 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 21328575 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 21328870 app.c:809 | app_main | Trying : NVFBC [I] 21333180 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 23361392 app.c:829 | app_main | Failed to find a supported capture interface [I] 23362813 app.c:982 | app_main | Host application exited [I] 31427180 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 31427598 app.c:771 | app_main | Looking Glass Host (B6) [I] 31427899 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 31428266 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 31429357 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 31432019 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 31432327 app.c:789 | app_main | IVSHMEM Address : 0x2C90000 [I] 31432636 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 31432910 app.c:791 | app_main | KVMFR Version : 19 [I] 31433200 app.c:809 | app_main | Trying : DXGI [I] 31435907 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 31436394 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 31436802 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 31437113 app.c:809 | app_main | Trying : NVFBC [I] 31440879 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 33445876 app.c:829 | app_main | Failed to find a supported capture interface [I] 33447315 app.c:982 | app_main | Host application exited [I] 49511667 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 49512415 app.c:771 | app_main | Looking Glass Host (B6) [I] 49513144 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 49513593 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 49514954 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 49517876 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 49518176 app.c:789 | app_main | IVSHMEM Address : 0x2A80000 [I] 49518522 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 49518884 app.c:791 | app_main | KVMFR Version : 19 [I] 49519267 app.c:809 | app_main | Trying : DXGI [I] 49522431 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 49522866 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 49523237 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 49523559 app.c:809 | app_main | Trying : NVFBC [I] 49527359 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 51532433 app.c:829 | app_main | Failed to find a supported capture interface [I] 51534312 app.c:982 | app_main | Host application exited [I] 8334037 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 8334749 app.c:771 | app_main | Looking Glass Host (B6) [I] 8335067 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 8335583 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 8336835 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 8339479 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 8339734 app.c:789 | app_main | IVSHMEM Address : 0x27B0000 [I] 8340024 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 8340275 app.c:791 | app_main | KVMFR Version : 19 [I] 8340590 app.c:809 | app_main | Trying : DXGI [I] 8360366 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 8360770 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 8361201 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 8361570 app.c:809 | app_main | Trying : NVFBC [I] 8367766 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 10421813 app.c:829 | app_main | Failed to find a supported capture interface [I] 10424161 app.c:982 | app_main | Host application exited [I] 11550645 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 11551071 app.c:771 | app_main | Looking Glass Host (B6) [I] 11551357 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 11551697 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 11552785 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 11555343 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 11555634 app.c:789 | app_main | IVSHMEM Address : 0x2770000 [I] 11555885 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 11556169 app.c:791 | app_main | KVMFR Version : 19 [I] 11556439 app.c:809 | app_main | Trying : DXGI [I] 11559638 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 11560061 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 11560412 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 11560717 app.c:809 | app_main | Trying : NVFBC [I] 11564821 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 13570109 app.c:829 | app_main | Failed to find a supported capture interface [I] 13572639 app.c:982 | app_main | Host application exited [I] 16477178 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 16477605 app.c:771 | app_main | Looking Glass Host (B6) [I] 16477906 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 16478265 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 16479362 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 16482077 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 16482403 app.c:789 | app_main | IVSHMEM Address : 0x2C00000 [I] 16482676 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 16483032 app.c:791 | app_main | KVMFR Version : 19 [I] 16483385 app.c:809 | app_main | Trying : DXGI [I] 16488668 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 16489313 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 16489836 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 16490293 app.c:809 | app_main | Trying : NVFBC [I] 16494966 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 18550203 app.c:829 | app_main | Failed to find a supported capture interface [I] 18552215 app.c:982 | app_main | Host application exited [I] 22808618 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 22809069 app.c:771 | app_main | Looking Glass Host (B6) [I] 22809588 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 22810061 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 22811236 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 22814093 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 22814444 app.c:789 | app_main | IVSHMEM Address : 0x2A60000 [I] 22814755 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 22815020 app.c:791 | app_main | KVMFR Version : 19 [I] 22815348 app.c:809 | app_main | Trying : DXGI [I] 22818909 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 22819409 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 22819955 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 22820421 app.c:809 | app_main | Trying : NVFBC [I] 22826070 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 24831748 app.c:829 | app_main | Failed to find a supported capture interface [I] 24833166 app.c:982 | app_main | Host application exited [I] 32912250 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 32912836 app.c:771 | app_main | Looking Glass Host (B6) [I] 32913256 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 32913628 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 32914905 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 32917541 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 32917815 app.c:789 | app_main | IVSHMEM Address : 0x2B50000 [I] 32918096 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 32918360 app.c:791 | app_main | KVMFR Version : 19 [I] 32918626 app.c:809 | app_main | Trying : DXGI [I] 32922889 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 32923411 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 32923987 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 32924650 app.c:809 | app_main | Trying : NVFBC [I] 32929475 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 34943983 app.c:829 | app_main | Failed to find a supported capture interface [I] 34945436 app.c:982 | app_main | Host application exited [I] 51020574 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 51021015 app.c:771 | app_main | Looking Glass Host (B6) [I] 51021369 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 51021738 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 51023198 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 51026120 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 51026433 app.c:789 | app_main | IVSHMEM Address : 0x2A10000 [I] 51026699 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 51027036 app.c:791 | app_main | KVMFR Version : 19 [I] 51027330 app.c:809 | app_main | Trying : DXGI [I] 51030461 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 51030921 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 51031281 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 51031623 app.c:809 | app_main | Trying : NVFBC [I] 51036964 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 53044009 app.c:829 | app_main | Failed to find a supported capture interface [I] 53046057 app.c:982 | app_main | Host application exited [I] 8930991 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 8931737 app.c:771 | app_main | Looking Glass Host (B6) [I] 8932059 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 8932372 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 8933646 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 8936349 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 8936610 app.c:789 | app_main | IVSHMEM Address : 0x27D0000 [I] 8936865 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 8937119 app.c:791 | app_main | KVMFR Version : 19 [I] 8937376 app.c:809 | app_main | Trying : DXGI [I] 8939968 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 8940436 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 8940811 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 8941151 app.c:809 | app_main | Trying : NVFBC [I] 8950546 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 10991647 app.c:829 | app_main | Failed to find a supported capture interface [I] 10994231 app.c:982 | app_main | Host application exited [I] 12133259 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 12133771 app.c:771 | app_main | Looking Glass Host (B6) [I] 12134173 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 12134560 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 12135784 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 12138999 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 12139288 app.c:789 | app_main | IVSHMEM Address : 0x27A0000 [I] 12139539 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 12139820 app.c:791 | app_main | KVMFR Version : 19 [I] 12140062 app.c:809 | app_main | Trying : DXGI [I] 12197368 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 12197862 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 12198232 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 12198522 app.c:809 | app_main | Trying : NVFBC [I] 12202511 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 14248559 app.c:829 | app_main | Failed to find a supported capture interface [I] 14250538 app.c:982 | app_main | Host application exited [I] 18151729 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 18152145 app.c:771 | app_main | Looking Glass Host (B6) [I] 18152462 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 18152829 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 18154016 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 18156806 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 18157077 app.c:789 | app_main | IVSHMEM Address : 0x2C30000 [I] 18157384 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 18157685 app.c:791 | app_main | KVMFR Version : 19 [I] 18157947 app.c:809 | app_main | Trying : DXGI [I] 18160938 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 18161399 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 18161853 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 18162408 app.c:809 | app_main | Trying : NVFBC [I] 18259901 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 20266018 app.c:829 | app_main | Failed to find a supported capture interface [I] 20267438 app.c:982 | app_main | Host application exited [I] 24423165 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 24423690 app.c:771 | app_main | Looking Glass Host (B6) [I] 24424065 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 24424451 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 24425555 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 24428237 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 24428547 app.c:789 | app_main | IVSHMEM Address : 0x2AF0000 [I] 24428878 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 24429148 app.c:791 | app_main | KVMFR Version : 19 [I] 24429446 app.c:809 | app_main | Trying : DXGI [I] 24433401 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 24433828 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 24434228 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 24434550 app.c:809 | app_main | Trying : NVFBC [I] 24439424 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 26446360 app.c:829 | app_main | Failed to find a supported capture interface [I] 26447775 app.c:982 | app_main | Host application exited [I] 34623876 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 34624304 app.c:771 | app_main | Looking Glass Host (B6) [I] 34624636 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 34624972 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 34626149 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 34628782 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 34629091 app.c:789 | app_main | IVSHMEM Address : 0x2BC0000 [I] 34629365 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 34629668 app.c:791 | app_main | KVMFR Version : 19 [I] 34629928 app.c:809 | app_main | Trying : DXGI [I] 34633291 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 34633749 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 34634148 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 34634481 app.c:809 | app_main | Trying : NVFBC [I] 34638754 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 36654984 app.c:829 | app_main | Failed to find a supported capture interface [I] 36657572 app.c:982 | app_main | Host application exited [I] 52791207 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 52791633 app.c:771 | app_main | Looking Glass Host (B6) [I] 52791964 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 52792293 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 52793372 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 52796145 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 52796439 app.c:789 | app_main | IVSHMEM Address : 0x2AF0000 [I] 52796747 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 52797033 app.c:791 | app_main | KVMFR Version : 19 [I] 52797327 app.c:809 | app_main | Trying : DXGI [I] 52800336 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 52800763 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 52801125 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 52801440 app.c:809 | app_main | Trying : NVFBC [I] 52805698 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 54810435 app.c:829 | app_main | Failed to find a supported capture interface [I] 54812558 app.c:982 | app_main | Host application exited [I] 134043695 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [W] 134044046 platform.c:500 | boostPriority | Failed to set realtime GPU priority. [I] 134044378 platform.c:501 | boostPriority | This is not a failure, please do not report this as an issue. [I] 134044775 platform.c:502 | boostPriority | To fix this, install and run the Looking Glass host as a service. [I] 134045175 platform.c:503 | boostPriority | looking-glass-host.exe InstallService [I] 134045490 app.c:771 | app_main | Looking Glass Host (B6) [I] 134045827 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 134046188 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 134047230 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 134049760 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 134050035 app.c:789 | app_main | IVSHMEM Address : 0x2B10000 [I] 134050384 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 134050691 app.c:791 | app_main | KVMFR Version : 19 [I] 134050953 app.c:809 | app_main | Trying : DXGI [I] 134054433 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 134054858 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 134055226 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 134055551 app.c:809 | app_main | Trying : NVFBC [I] 134059479 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 136094862 app.c:829 | app_main | Failed to find a supported capture interface [I] 136097766 app.c:982 | app_main | Host application exited [I] 6137763 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 6138521 app.c:771 | app_main | Looking Glass Host (B6) [I] 6138934 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 6139288 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 6140198 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 6142666 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 6142955 app.c:789 | app_main | IVSHMEM Address : 0x27C0000 [I] 6143205 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 6143494 app.c:791 | app_main | KVMFR Version : 19 [I] 6143735 app.c:809 | app_main | Trying : DXGI [I] 6180849 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 6181226 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 6181613 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 6181908 app.c:809 | app_main | Trying : NVFBC [I] 6196049 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 6201056 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 6201351 app.c:829 | app_main | Failed to find a supported capture interface [I] 6203552 app.c:982 | app_main | Host application exited [I] 7318480 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 7318867 app.c:771 | app_main | Looking Glass Host (B6) [I] 7319182 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 7319537 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 7320593 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 7322948 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 7323205 app.c:789 | app_main | IVSHMEM Address : 0x2A00000 [I] 7323461 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 7323714 app.c:791 | app_main | KVMFR Version : 19 [I] 7323953 app.c:809 | app_main | Trying : DXGI [I] 7329994 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 7330375 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 7330753 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 7331096 app.c:809 | app_main | Trying : NVFBC [I] 7336345 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 7341425 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 7341722 app.c:829 | app_main | Failed to find a supported capture interface [I] 7344445 app.c:982 | app_main | Host application exited [I] 9406553 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 9407089 app.c:771 | app_main | Looking Glass Host (B6) [I] 9407382 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 9407728 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 9408829 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 9412127 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 9412396 app.c:789 | app_main | IVSHMEM Address : 0x2750000 [I] 9412684 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 9412930 app.c:791 | app_main | KVMFR Version : 19 [I] 9413215 app.c:809 | app_main | Trying : DXGI [I] 9463604 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 9463984 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 9464366 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 9464661 app.c:809 | app_main | Trying : NVFBC [I] 9469672 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 9475026 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 9475344 app.c:829 | app_main | Failed to find a supported capture interface [I] 9477127 app.c:982 | app_main | Host application exited [I] 13785523 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 13785898 app.c:771 | app_main | Looking Glass Host (B6) [I] 13786234 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 13786593 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 13787687 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 13790313 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 13790611 app.c:789 | app_main | IVSHMEM Address : 0x2A30000 [I] 13790914 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 13791181 app.c:791 | app_main | KVMFR Version : 19 [I] 13791468 app.c:809 | app_main | Trying : DXGI [I] 13793940 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 13794332 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 13794716 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 13795053 app.c:809 | app_main | Trying : NVFBC [I] 13800492 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 13805244 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 13805557 app.c:829 | app_main | Failed to find a supported capture interface [I] 13806850 app.c:982 | app_main | Host application exited [I] 21880213 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 21880618 app.c:771 | app_main | Looking Glass Host (B6) [I] 21880971 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 21881298 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 21882394 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 21884781 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 21885056 app.c:789 | app_main | IVSHMEM Address : 0x2A40000 [I] 21885327 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 21885600 app.c:791 | app_main | KVMFR Version : 19 [I] 21885865 app.c:809 | app_main | Trying : DXGI [I] 21887928 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 21888323 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 21888721 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 21889036 app.c:809 | app_main | Trying : NVFBC [I] 21893977 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 21898647 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 21898964 app.c:829 | app_main | Failed to find a supported capture interface [I] 21900267 app.c:982 | app_main | Host application exited [I] 37979383 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [I] 37979825 app.c:771 | app_main | Looking Glass Host (B6) [I] 37980195 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 37980524 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 37981579 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 37984505 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 37984815 app.c:789 | app_main | IVSHMEM Address : 0x2A50000 [I] 37985087 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 37985387 app.c:791 | app_main | KVMFR Version : 19 [I] 37985727 app.c:809 | app_main | Trying : DXGI [I] 37988026 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 37988424 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 37988777 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 37989091 app.c:809 | app_main | Trying : NVFBC [I] 37994471 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 37999603 wrapper.cpp:94 | NvFBCInit | Failed to enable the NvFBC interface: 0 [E] 37999933 app.c:829 | app_main | Failed to find a supported capture interface [I] 38001241 app.c:982 | app_main | Host application exited [I] 572897341 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [W] 572897797 platform.c:500 | boostPriority | Failed to set realtime GPU priority. [I] 572898098 platform.c:501 | boostPriority | This is not a failure, please do not report this as an issue. [I] 572898609 platform.c:502 | boostPriority | To fix this, install and run the Looking Glass host as a service. [I] 572899132 platform.c:503 | boostPriority | looking-glass-host.exe InstallService [I] 572899501 app.c:771 | app_main | Looking Glass Host (B6) [I] 572899920 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 572900307 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 572901566 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 572904263 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 572904546 app.c:789 | app_main | IVSHMEM Address : 0x2B60000 [I] 572904866 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 572905254 app.c:791 | app_main | KVMFR Version : 19 [I] 572905528 app.c:809 | app_main | Trying : DXGI [I] 572908466 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 572908961 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 572909370 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 572909738 app.c:809 | app_main | Trying : NVFBC [I] 572914143 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 574933799 app.c:829 | app_main | Failed to find a supported capture interface [I] 574936400 app.c:982 | app_main | Host application exited [I] 1127229414 time.c:85 | windowsSetTimerResolution | System timer resolution: 488.2 μs [W] 1127229811 platform.c:500 | boostPriority | Failed to set realtime GPU priority. [I] 1127230340 platform.c:501 | boostPriority | This is not a failure, please do not report this as an issue. [I] 1127230770 platform.c:502 | boostPriority | To fix this, install and run the Looking Glass host as a service. [I] 1127231134 platform.c:503 | boostPriority | looking-glass-host.exe InstallService [I] 1127231441 app.c:771 | app_main | Looking Glass Host (B6) [I] 1127231739 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics [I] 1127232060 cpuinfo.c:38 | lgDebugCPU | CPU: 2 sockets, 2 cores, 2 threads [I] 1127233104 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x8, device 0x1, function 0x0 [I] 1127236550 app.c:788 | app_main | IVSHMEM Size : 32 MiB [I] 1127236840 app.c:789 | app_main | IVSHMEM Address : 0x2DF0000 [I] 1127237116 app.c:790 | app_main | Max Pointer Size : 1024 KiB [I] 1127237380 app.c:791 | app_main | KVMFR Version : 19 [I] 1127237654 app.c:809 | app_main | Trying : DXGI [I] 1127241063 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [I] 1127241540 dxgi.c:319 | dxgi_init | Not using unsupported adapter: Microsoft Basic Render Driver [E] 1127241932 dxgi.c:384 | dxgi_init | Failed to locate a valid output device [I] 1127242288 app.c:809 | app_main | Trying : NVFBC [I] 1127246415 wrapper.cpp:90 | NvFBCInit | NvFBC SDK Version: 112 [E] 1129273644 app.c:829 | app_main | Failed to find a supported capture interface [I] 1129275226 app.c:982 | app_main | Host application exited ~~~~~~~~~ virt-manager vm configuration <domain type="kvm"> <name>win11</name> <uuid>93a6e2fa-d612-4939-ae76-2045c63f2fd9</uuid> <metadata> <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0"> <libosinfo:os id="http://microsoft.com/win/11"/> </libosinfo:libosinfo> </metadata> <memory unit="KiB">8388608</memory> <currentMemory unit="KiB">8388608</currentMemory> <vcpu placement="static">4</vcpu> <os> <type arch="x86_64" machine="pc-q35-7.2">hvm</type> <boot dev="hd"/> </os> <features> <acpi/> <apic/> <hyperv mode="custom"> <relaxed state="on"/> <vapic state="on"/> <spinlocks state="on" retries="8191"/> </hyperv> <vmport state="off"/> </features> <cpu mode="host-passthrough" check="none" migratable="on"/> <clock offset="localtime"> <timer name="rtc" tickpolicy="catchup"/> <timer name="pit" tickpolicy="delay"/> <timer name="hpet" present="no"/> <timer name="hypervclock" present="yes"/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>destroy</on_crash> <pm> <suspend-to-mem enabled="no"/> <suspend-to-disk enabled="no"/> </pm> <devices> <emulator>/usr/bin/qemu-system-x86_64</emulator> <disk type="file" device="disk"> <driver name="qemu" type="qcow2"/> <source file="/home/ishai/windows-disk.qcow2"/> <target dev="sda" bus="sata"/> <address type="drive" controller="0" bus="0" target="0" unit="0"/> </disk> <controller type="usb" index="0" model="qemu-xhci" ports="15"> <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/> </controller> <controller type="pci" index="0" model="pcie-root"/> <controller type="pci" index="1" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="1" port="0x10"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/> </controller> <controller type="pci" index="2" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="2" port="0x11"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/> </controller> <controller type="pci" index="3" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="3" port="0x12"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/> </controller> <controller type="pci" index="4" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="4" port="0x13"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/> </controller> <controller type="pci" index="5" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="5" port="0x14"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/> </controller> <controller type="pci" index="6" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="6" port="0x15"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/> </controller> <controller type="pci" index="7" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="7" port="0x16"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/> </controller> <controller type="pci" index="8" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="8" port="0x17"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/> </controller> <controller type="pci" index="9" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="9" port="0x18"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/> </controller> <controller type="pci" index="10" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="10" port="0x19"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/> </controller> <controller type="pci" index="11" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="11" port="0x1a"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/> </controller> <controller type="pci" index="12" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="12" port="0x1b"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/> </controller> <controller type="pci" index="13" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="13" port="0x1c"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/> </controller> <controller type="pci" index="14" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="14" port="0x1d"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/> </controller> <controller type="pci" index="15" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="15" port="0x1e"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x6"/> </controller> <controller type="pci" index="16" model="pcie-to-pci-bridge"> <model name="pcie-pci-bridge"/> <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/> </controller> <controller type="sata" index="0"> <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/> </controller> <controller type="virtio-serial" index="0"> <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/> </controller> <interface type="user"> <mac address="52:54:00:a6:78:3f"/> <model type="e1000e"/> <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/> </interface> <serial type="pty"> <target type="isa-serial" port="0"> <model name="isa-serial"/> </target> </serial> <console type="pty"> <target type="serial" port="0"/> </console> <input type="mouse" bus="virtio"> <address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/> </input> <input type="keyboard" bus="virtio"> <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/> </input> <input type="mouse" bus="ps2"/> <input type="keyboard" bus="ps2"/> <graphics type="spice" autoport="yes"> <listen type="address"/> <image compression="off"/> <gl enable="no"/> </graphics> <sound model="ich9"> <address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/> </sound> <audio id="1" type="none"/> <video> <model type="vga" vram="16384" heads="1" primary="yes"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/> </video> <hostdev mode="subsystem" type="pci" managed="yes"> <source> <address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/> </source> <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/> </hostdev> <hostdev mode="subsystem" type="pci" managed="yes"> <source> <address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/> </source> <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/> </hostdev> <memballoon model="virtio"> <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/> </memballoon> <shmem name="looking-glass"> <model type="ivshmem-plain"/> <size unit="M">32</size> <address type="pci" domain="0x0000" bus="0x10" slot="0x01" function="0x0"/> </shmem> </devices> </domain>
