Just want to know if anyone has successfully run 3600Mhz bins of Micron E-die stable on processors like the 7900X, 9820X and 10900X? (or any 44 lane Skylake-X processor)
3600Mhz is cheaper than 3200Mhz at the moment and I’d want to get 3600, but I don’t want to end up in a position that it doesn’t post. Crucial Ballistix is also not on the QVL for my board, so I’m extra weary.
How about 3000 CL15 ? Pretty much the same bin as 3200 CL16.
In a month or two I will be able to tell you about how 4*16 E-die does on a 7820X, but there is no plan to push it beyond the 3000 XMP, it is going into a DIY server.
SKL-X/CSL-X memory controller does not like high frequencies too much, but the SPD on the sticks is programmed to default to something like JEDEC 2133 or 2400, so no-post is probably unlikely, unless you try 8*16.
