Definitely would like to see a review of the mATX boards ASRock offers from B650 (Oddly no B650E mATX) for use in homelab and VFIO.
https://www.asrock.com/mb/AMD/B650M%20PG%20Riptide/index.asp
AsRock offers B650E only as mITX
https://www.asrock.com/mb/AMD/B650E%20PG-ITX%20WiFi/index.asp
Yeah, that’s not enough PCI-E slots for homelab. Which is why I asked about the B650 non-E mATX boards.
To reply to the B650E Steel Legend video on PCI-E peripherals I use:
I use a capture card, USB controller currently with my systems.
However, for my homelab build, I will be using a M.2 to PCI-e X4 riser to support a 6 port ASMedia PCI-E SATA controller, and instead of a capture card, the x4 slot will have a 10Gbe NIC. I will also have a Intel i210 NIC on a PCI-E riser, and the USB 3.0 controller card.
I’m specifically choosing a RX 6800 reference because it’s 2 slots for using one of the B650M Riptide’s x1 slots without a riser, and the one under the GPU uses a riser.
Will definitely want to see a review of this since it’s a B650E in mATX with dual 10G NICs:
