Hi all,
I’m building a new system in a new to me case style.
Since the Meshify 2 XL will physically fit a SSI-EEB I thought they would account for the covered cable access holes.
Nope, my bad.
Until I had the MB mounted, it didn’t look too bad.
Routing all of the power looks to be either up from the ‘basement’ along the right side or take out the ‘vertical wall’ and come around from the side up by the power connection on the MB.
Even with PSU extensions, coming over the top, using the top wire management holes, would be an ugly mess.
Since it’s mine now I can modify it as I want, but the Vertical wall does not seem to be a good place to make neat holes without potentially making a mess of things.
I don’t intend to use the added drive spaces anytime soon, so having the ‘Vertical wall’ missing would be kind of a noticeable gap in the look and might mess up the airflow from the front some. I do need that. All air cooled ( at this time ).
Anyhow. Any suggestions appreciated.
Thanks.
