In my current place I have a pfsense box and ubiquity AP with a switch.
I want to simplify and go with a Mesh WiFi system.
Want good QOS and need port forwarding for Nextcloud. I would like to be able to admin it via an Android app.
The Master router will be hooked up to a switch and small UPS.
House is 1600sqft single story.
Two people with about three devices a piece. 4K streaming, gaming and will have a security system with outdoor cameras on the network.
Will be building a NAS (Plex and Nextcloud) and Steam in home streaming server to put on the network. So, NAT loopback would be nice or the ability to point device at a single URL either on the network or not.
Velop has basic functionality and is renamed “Device Prioritization”
The name is pretty much a good description. I have no experience with that feature due to my setup being different with PFSense being the router with the Velop devices acting as MESH APs rather than MESH System.
While researching the Orbi, it looks like Netgear hides the QoS functionality and may be removing it in the future.
A bit off-topic, but it seems like Mesh devices are designed to be somewhat like a set piece, so it doesn’t look like an ugly device that has no place being where it is.
buddy of mine at work went with the google mesh and they arent terrible. they wont do mesh as ap only though, so you either go double nat or forget the pfsense box.
The Google Mesh routers provide a lot of control away from home. In all honesty a lot of the features are excellent for people who have a family. Cause a lot of the good features are the limiting speeds on devices and or making sure network speed is prioritized on one device as opposed to another.
Also If your network goes down you will receive notification telling you your network is down.
The guy at work who has the google mesh stuff knows nothing about networking and he had no issues. I would say they are about as simple as mesh gets.
For me I would probably go with the asus AiMesh stuff but I’m lazy and cheap so I just stick with non mesh on 3 different access points. Sometimes I have to switch manually but it doesnt bug me.
I am having a similar dilemma, except I am already moved in…
Currently, I’m using a pair of Asus AC-86u’s for their AiMesh. It worked well at first but it seems that Asus can’t be bothered to produce quality firmware updates for my particular models.
While they have an Android app and its simple and easy to setup and works for the most part, I’d be lying if I said I loved it and it works 100% perfectly.
I’ve been looking for an alternative to take advantage of my wired backhaul (already in use with my current setup).
For your situation, I’ll suggest you just grab a Ubiquiti USG, add your NAS to the switch, drop your pfsense box and add APs as necessary… thats pretty much what I might do anyways, but to humor you I’ll divulge my full option list.
Please note: These below options are for my use case, so please ignore if this doesn’t fit your mold
Yea I appreciate you addressing both our issues, I didn’t mean to hijack the thread.
I’ve been thinking mostly about the all UniFi gear setup as my end game, but in the meantime just turning off bandwidth steering because AiMesh’s sucks.
I’ll likely add a PFsense box in my mix at some point since my ISP allows me to run all my own gear already anyways.
I checked on the Merlin stuff, I would have to run a router + repeater which I don’t want to do.
