I want to connect my NAS to my PC on a faster than 1G connection. I’ve found ConnectX 2 VPI cards for 9€ each (I know they are old but should still work for now and ConnectX 3 or similar newer cards are 60€ or more) but they are QSFP. They are IBM branded, model number 81Y1533.
I’ve also found some QSFP to QSFP DAC cables but they are listed as SAS cables. Can I use them to connect both cards for networking? They are made by NetApp, model number X6558-R6 / 112-00177.
Will that combination work? I’m looking to get a cheap setup running just to try it out, I can get the cable for 14€ where a Mellanox cable from FS.com would cost me around 45€.
When Nvidia bought Mellanox they did away with being able to easily get drivers for EOL devices like the ConnectX 2. So hopefully your OS has drivers built in, otherwise you might be SOL if some hunting around google doesnt get you the right driver for that NIC.
Personally, Id skip that card because of the driver situation
