I recently decided on these drives from Toshiba. Toshiba MG10
No nand flash assist, just helium CMR drives that are quite cheaper. Make sure to check the model number if you wanna buy it. MG10ACA20TA Is the normal one.
I read into detail of some nand flash assist and they promise like 60TB of lifespan on a 20TB drive, (ex. WD enterprise) so I was concerned about that and just bought 2 MG10. There was 3 drives in stock anyways.
On a QNAP 2 drive NAS, it does make bit of a sound on random reads, but I bet any 120mm fan on a bigger NAS would be louder.
One thing to consider if you’re going to be making a big array is rebuild and scrub times, with the exception of dual actuator drives, bigger hard drives aren’t getting any faster which can make more (relatively) smaller hdds look better.
Depending on how risk adverse you are, you may want to wait to see what the reliability of denser hdds ends up being. Almost all the ~18TB and up hdds use EAMR technology instead of CMR which isn’t as proven.
Actually, let me walk back my statement slightly. It is HAMR HDDs that I think are an unproven technology with a possibility of high future failure rates; because they heat sections of the platter to roughly curie temperature repeatedly and I feel like sooner or later the magnetic coating would delaminate.
I don’t understand how MAMR HDDs work well enough to say they sound unreliable.
Both HAMR and MAMR HDDs fall under the umbrella of EAMR.
Technically EAMR HDDs can be conventional or shingled, but to me when someone says CMR, I assume the drive isn’t EAMR.
WD reds are sweet, and their performance is undeniable.
but if you are building a 20 drive server, for network traffic, and you’re running some raid, my guess you would not feel much of a difference.
i recently changed a WD red 6 TB for a toshiba 6TB for a raspberrypi NAS, and there’s a ~minor difference in performance, but if you got 20 x whatever, performance, you should be safe, its like saying i hit the target with a bazooka.
spec wise the main difference should be 128mb v 256mb cache, and 5400 v. 7200 rpm performance, pr. disc.
but raided, over network, there should’nt be much of a performance difference.
The sweet spot is GB/$. But that $ must include the cost of each drive bay. Let’s say your server cost $2000, so each drive bay cost $100. Add that to the price of the drive.
