Mechanical Keyboard Corner
Yeah, decent noise gates, good distance from the mic if possible.
And like @SgtAwesomesauce said Zilents or other interanly silenced switch will do a lot. I have the Zilents and the U4 Boba, I love both, I prefer the tactile profile of the U4.
Can also put foam or padding in the bottom of the case and under the board to stop the transfer through to the desk.
RTX voice and having a mic close to my mouth helps, it doesn’t activate unless i talk and it even filters out my AC.
cherry reds + O-rings VS cherry red silents
i’m impressed
Got some more switches on the mail today, with Aliexpress coupons i got these for dirt cheap and they feel preeeety good on the hand , I think I’m gonna use them on my ID80, instead of the Akkos i originally intended to use.
Bought all the parts for my ā€œendgameā€, at least i hope as it is a bit more expensive than i kind of budgetted.
Case/PCB: YMDK Melody 96 Black/Blue with Aluminum underside and brass weight, with hot swap ANSI layout.
Switches:Keebwerk Bushi, from my testing they come out above some of the other tactiles like pandas/zealios/zilents (i have 10 different tactiles)
Keyset: already have them (ordered last year) PBT Infinikey Amalfi
( https://prototypist.net/products/group-buy-infinikey-amalfi )
Other stuff:
Durock screw in stabilizers
Switch films (only a couple of euro and it might be needed)
Foam padding for under the plate
I know i’ve kind of gone off the deep end with the keyboard stuff, let’s just call it a hobby?
My biggest issue with some of the other tactiles is that the electric actuation point is a bit lower than the ā€œbumpā€, as i get more used to a keyboard i won’t press as hard and then don’t bottom out. sometimes i get double clicks and sometimes it won’t activate. Also, i like having a tactile bump right away instead of a ā€œdeadā€ zone.
I have this. I do wish there was a gap separating arrows and numpad from the main typing area, and lock lights would be nice. It can be difficult to home. High contrast key caps help.
They don’t fit all switches just FYI. They didn’t physically work in my holy pandas. I’ve mostly seen them used on gaterons and I think they work with stock cherry.
Yo
YO
I want.
It’s cool, but I’m not sure what I’d do with it.
Wait… is that starting to matter in this hobby?
I just have too much crap that sits idle.
I feel both these replies… Deep.
Macros
So many macros
i took my corsair k60 with dead/failing ASDF keys mostly apart, tested the switch contacts with multimeter, they seem fine. tested the diodes around the A-F keys, they seem fine too.
any suggestions? i only have access to the bottom side of the circuit board right now, if i need to take every switch apart to separate the circuit board from the aluminum top plate i’m done with it.
i don’t specifically know how the K60 is built, but generally it could be an issue with the matrix. How do they fail? does it also fail when using other buttons in the same row/column?
the ASDF keys began intermittently not working just normal typing. within a couple hrs or less of trying different things to see if i could nail down a pattern to make them fail or work, they stopped working completely. There was a lot of dust and debris in the tray so there could be a very slim chance that just finally cleaning out the crud could fix it? i dunno, might try putting it back together just enough to test later today.
Yes, yes you would.
Plate mount boards suck to service.
Unless hot swap. Still not super easy but much better.
Raspberry pie built into model m?
coughs
