Mayflower Idea
Build Logan's perfect HEADSET and sell for under $200.
Good sounding removable or retractable mic with great all around sound for gaming and music listening.  Screw on 1/4" jack adapter. Straight cable.  Those pads he's crazy about.  Daisy chaining/reversible input on headset.
Make a bundle version with DAC discounted and maybe a wireless version and some adapters for consoles available as well.  Just keep that all in mind and make it really flexible and keep a good build quality and make it really durable.
It would be nice as well if the mic could come right off for people like me who don't use mics 99% of the time.
Other than that, make them fairly neutral without too much of bass or treble, straight braided cable, nice pads, and the ability to plug the cord(s) into either side. Essentially take the DT880 type of headphones and make them more gamer friendly.
What about the mic is removeable and through that port you could daisy chain that would be absurdly excellent
Or if the mic was a pass-through type setup where you could plug it into the headphone on whichever side and plug the cable to the computer into it, or a daisy chain cable, or nothing and just have the mic on one side and the cable to the computer on the other.
I think a modular system like that would work nice since it would allow people to run cables and mics any way they want. I personally would run it with the cable to the computer on the right and the mic on the left, but if I was playing with somebody next to me I'd probably run it with the cable to the computer and the daisy chain on the left with the mic on the right since I find sitting directly next to another person's mic to be kinda awkward.
Yeah that would be ideal two 3.5 ports on each side where you can input, output or pass-through on each unfortunately I don't think that is possible unless someone wants to explain how?
I feel like it would only work if there was extra cabling going through the headband for the mic. V-MODA makes a removable mic (BoomPro Microphone) which is where I got the idea from, but have a 3.5 TRRS male and a 3.5 TRRS female connector. I'm not an engineer, but I think it would be possible if there is a wire that runs between each 3.5 connector on the headphones, bypassing the speakers entirely. That way the mic can allow audio to pass through it, while still having the mic audio to travel to the computer or whatever. I think that would also allow daisy chaining without having the mic audio going to the second pair of headphones (because if you're sitting next to somebody you shouldn't need the mic audio going to the second pair).
I'm running on little sleep right now so my wording probably sucks, but I'll try to make a diagram of what I mean later.
Something like that I think?
EDIT: The colored boxes on the side are supposed to represent the plug-ins on the headphones and the lines leading from them would be the wiring.
There's plenty of mods out there already. All you need is a tiewrap and cheap mic (and a pair of cans obviously ;))
Might be cool if you drill a hole in the t50rp can and add a female jack tho. No soldering needed. Add the original cable to a shoelace cable mod together with the mic cable.
http://imgur.com/gallery/bKU4H
