What would be the difference ? i would really enjoy a answer with some reasons instead of just an opinion
I know the audio is better but anything else?
The Asus Impact is a much better board overall, better Vreg. (power dilivery) so if you want to go into overclocking the impac would be a better choice.
Ye i thought about that also, but then i heard somebody say it wasent needed for haswell? (a source whom i dont know if is trustworthy)
All the other features that impact has are what I think sets it apart like the dedicated sound card, full v reg, all the asus software and bios features are really nice and also has dual band wifi
Correct me if im wrong, but doesnt the Asrock have basicly the same wifi?
Also.. What are these softwares and bios features that the asrock doesnt have?
Bump
The Asrock has 6 sata ports instead of 4 on the impact, further the Asrock contains 2 usb 2.0 headers on the board instead of 1 usb 2.0 header on the impact, but the impact contains 2 more usb 2.0 ports on the back, so at that level they are equal, but the Impact has probably a better sound chip, and it has a much better vreg.
Thats why i personaly would recommend the impact.
Also a realy good option could be the EVGA Z87 Stinger.
In my country the evga somehow manages to cost 45$ more than impact :(
wow no thats not worth it ☺
Also a cheaper option could be the Asus Z87i-Deluxe. but you have to like the color theme...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132028
Guess what.. In my lovely country, there aint a single retailer of the Z87i-deluxe :o
What does the better Vreg matter for ? you say overclocking but how? stability?
Better vreg gives you better overclock headroom and also stability. the impact is a sweet little power board, tobad there is not retailer in your country for the Deluxe, because this board has also a very great Vreg, seems to be that all my idea´s are not on sale on there.
But if you plan to overclock i would realy recommend the impact then, because of its great vreg with 16Ampérage chokes thats great for such a small powerboard. this give you more stability wenn overclock. Hasswell is allready a hard cpu to overclock because it has its own voltage regulator inside, so thats why i recommend a board with a decent vreg, just to make sure everything is allright.
This offcourse does not mean that the Asrock is a bad choice, i only don´t know what the quality is of the componants they used on this board..
Dont get me wrong. i really appreciate the help i am just trying to also understand so in the future ill have more knowledge :) Thanks
its okay . its allways good to try to understand things. ☺
i am also learning everyday my self. ☺
Ah i found a place that retails Asus Z87i-PRO, it costs 64$ less than Impact
So basicly the difference between those is just the AC wireless, soundcard and some software? (color doesnt matter as it will be in a non window case)
EDIT: Btw. Do you have any idea how the Audio on the z87i-pro is against the supremefx card on this mb? http://www.asus.com/Motherboards/CROSSHAIR_III_FORMULA/#overview
well i just looked at the specs of the Z87i-pro and this board also looks very sweet. 12+2 powerphase digi vrm. wifi Bluetooth. seems a very nice board to me.
About the sound chip. i not realy know the diffrence, i only know that the ipro uses a realtek ALC1150 HD audio codec and the impact uses the Supreme FX audio codec. i think the supreme FX would be better, but the big question is it worth it? if you are a audiophile then maybe yes. but i still think the I-pro has also a good sound chip onboard.
I think the the Asus Z87i-pro is not a bad choice. you can spend the money you save else where.
http://www.asus.com/Motherboards/Z87IPRO/#overview
