Another oddity. I can passthrough the Chelsio NICs (function 4) to HVMs no problem:
root@archiso ~ # ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enX0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:16:3e:22:85:36 brd ff:ff:ff:ff:ff:ff
inet 192.168.69.17/24 metric 100 brd 192.168.69.255 scope global dynamic enX0
valid_lft 3385sec preferred_lft 3385sec
inet6 fe80::216:3eff:fe22:8536/64 scope link proto kernel_ll
3: ens5f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:07:43:4b:f7:e0 brd ff:ff:ff:ff:ff:ff
altname enp0s5f0
inet 192.168.1.15/24 metric 100 brd 192.168.1.255 scope global dynamic ens5f0
valid_lft 86191sec preferred_lft 86191sec
inet6 fe80::207:43ff:fe4b:f7e0/64 scope link proto kernel_ll
4: ens5f0d1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:07:43:4b:f7:e8 brd ff:ff:ff:ff:ff:ff
altname enp0s5f0d1
5: ens5f0d2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:07:43:4b:f7:f0 brd ff:ff:ff:ff:ff:ff
altname enp0s5f0d2
6: ens5f0d3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:07:43:4b:f7:f8 brd ff:ff:ff:ff:ff:ff
altname enp0s5f0d3
Note that two interfaces got assigned IP addreses - enX0 is a virtualized management LAN, ens5f0 is the physical NIC connection to my router.
root@archiso ~ # dmesg | grep cxgb4
[ 4.899632] cxgb4 0000:00:05.0: Coming up as MASTER: Initializing adapter
[ 5.596729] cxgb4 0000:00:05.0: Direct firmware load for cxgb4/t5-config.txt failed with error -2
[ 6.533372] cxgb4 0000:00:05.0: Successfully configured using Firmware Configuration File "Firmware Default", version 0x0, computed checksum 0x0
[ 6.766686] cxgb4 0000:00:05.0: Hash filter supported only on T6
[ 6.816682] cxgb4 0000:00:05.0: max_ordird_qp 21 max_ird_adapter 387072
[ 6.856683] cxgb4 0000:00:05.0: Current filter mode/mask 0x632b:0x21
[ 7.010427] cxgb4 0000:00:05.0: 130 MSI-X vectors allocated, nic 32 eoqsets 32 per uld 8 mirrorqsets 32
[ 7.010647] cxgb4 0000:00:05.0: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 7.061697] cxgb4 0000:00:05.0 eth1: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 7.061938] cxgb4 0000:00:05.0 eth2: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 7.062141] cxgb4 0000:00:05.0 eth3: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 7.062330] cxgb4 0000:00:05.0 eth4: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 7.099978] cxgb4 0000:00:05.0: Chelsio T540-BT rev 1
[ 7.099981] cxgb4 0000:00:05.0: S/N: PT40180192, P/N: 110124450A0
[ 7.099983] cxgb4 0000:00:05.0: Firmware version: 1.27.5.0
[ 7.099984] cxgb4 0000:00:05.0: Bootstrap version: 1.1.0.0
[ 7.099985] cxgb4 0000:00:05.0: TP Microcode version: 0.1.4.9
[ 7.099986] cxgb4 0000:00:05.0: No Expansion ROM loaded
[ 7.099987] cxgb4 0000:00:05.0: Serial Configuration version: 0x1009000
[ 7.099988] cxgb4 0000:00:05.0: VPD version: 0x2
[ 7.099989] cxgb4 0000:00:05.0: Configuration: RNIC MSI-X, Offload capable
[ 11.817237] cxgb4 0000:00:05.0 ens5f0: renamed from eth1
[ 11.854079] cxgb4 0000:00:05.0 ens5f0d2: renamed from eth3
[ 11.922367] cxgb4 0000:00:05.0 ens5f0d1: renamed from eth2
[ 11.977684] cxgb4 0000:00:05.0 ens5f0d3: renamed from eth4
[ 15.401824] cxgb4 0000:00:05.0 ens5f0: link up, 1Gbps, full-duplex, Tx/Rx PAUSE
Now for comparison I’ll start the same Xen configuration, but as PV instead of HVM (I’d prefer PVH but the PCI passthrough not implemented thingy…)
3: enp0s0f4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet 192.168.1.15/24 metric 100 brd 192.168.1.255 scope global dynamic enp0s0f4
valid_lft 86386sec preferred_lft 86386sec
4: enp0s0f4d1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
5: enp0s0f4d2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
6: enp0s0f4d3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
Notice no address on the management interface. Any attempt to configure it with DHCP will fail, static assignment also doesn’t help, i.e. pings don’t work in any way.
[ 14.720529] cxgb4 0000:00:00.4: Xen PCI mapped GSI32 to IRQ77
[ 14.766826] cxgb4 0000:00:00.4: Coming up as MASTER: Initializing adapter
[ 16.445938] cxgb4 0000:00:00.4: Successfully configured using Firmware Configuration File "/lib/firmware/cxgb4/t5-config.txt", version 0x1425001c, computed checksum 0xd8c8fbd6
[ 16.622529] cxgb4 0000:00:00.4: Hash filter supported only on T6
[ 16.672608] cxgb4 0000:00:00.4: max_ordird_qp 21 max_ird_adapter 387072
[ 16.712537] cxgb4 0000:00:00.4: Current filter mode/mask 0x632b:0x21
[ 16.813999] cxgb4 0000:00:00.4: too many vectors (0x82) for PCI frontend: Increase SH_INFO_MAX_VEC
[ 16.814034] cxgb4 0000:00:00.4: Xen PCI frontend error: -22!
[ 16.815542] cxgb4 0000:00:00.4: enable msix get err ffffffe4
[ 16.815560] cxgb4 0000:00:00.4: Xen PCI frontend error: -28!
[ 16.815684] cxgb4 0000:00:00.4: Disabling MSI-X due to insufficient MSI-X vectors
[ 16.815924] cxgb4 0000:00:00.4: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 16.880617] cxgb4 0000:00:00.4 eth0: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 16.880877] cxgb4 0000:00:00.4 eth1: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 16.881117] cxgb4 0000:00:00.4 eth2: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 16.881354] cxgb4 0000:00:00.4 eth3: Chelsio T540-BT 100M/1G/10GBASE-BT_XFI
[ 16.919202] cxgb4 0000:00:00.4: Chelsio T540-BT rev 1
[ 16.919205] cxgb4 0000:00:00.4: S/N: PT40180192, P/N: 110124450A0
[ 16.919212] cxgb4 0000:00:00.4: Firmware version: 1.27.5.0
[ 16.919214] cxgb4 0000:00:00.4: Bootstrap version: 1.1.0.0
[ 16.919215] cxgb4 0000:00:00.4: TP Microcode version: 0.1.4.9
[ 16.919216] cxgb4 0000:00:00.4: No Expansion ROM loaded
[ 16.919217] cxgb4 0000:00:00.4: Serial Configuration version: 0x1009000
[ 16.919219] cxgb4 0000:00:00.4: VPD version: 0x2
[ 16.919220] cxgb4 0000:00:00.4: Configuration: RNIC MSI, Offload capable
[ 16.939658] cxgb4 0000:00:00.4 enp0s0f4: renamed from eth0
[ 16.979387] cxgb4 0000:00:00.4 enp0s0f4d3: renamed from eth3
[ 16.999341] cxgb4 0000:00:00.4 enp0s0f4d2: renamed from eth2
[ 17.029394] cxgb4 0000:00:00.4 enp0s0f4d1: renamed from eth1
[ 19.800967] cxgb4 0000:00:00.4 enp0s0f4: link up, 1Gbps, full-duplex, Tx/Rx PAUSE
Notice the bit about insufficient MSI-X vectors and SH_INFO_MAX_VEC. So I checked and… well…
In the HVM passthrough you can see the card gets 130 vectors. On the host it gets even more:
root@vmserver:/opt/xen # dmesg | grep -i msi-x
[ 6.713113] cxgb4 0000:17:00.4: 162 MSI-X vectors allocated, nic 32 eoqsets 32 per uld 16 mirrorqsets 32
[ 6.800866] cxgb4 0000:17:00.4: Configuration: RNIC MSI-X, Offload capable
[ 8.854739] cxgb4 0000:18:00.4: 162 MSI-X vectors allocated, nic 32 eoqsets 32 per uld 16 mirrorqsets 32
[ 8.944282] cxgb4 0000:18:00.4: Configuration: RNIC MSI-X, Offload capable
[ 17.364304] cxgb4vf 0000:17:01.0: eth0: Chelsio VF NIC PCIe MSI-X
[ 17.564546] cxgb4vf 0000:17:01.4: eth1: Chelsio VF NIC PCIe MSI-X
[ 1532.330417] pciback 0000:17:00.4: xen_pciback: error enabling MSI-X for guest 3: err -28!
The last pciback error is consistent, as the SH_INFO_MAX_VEC limit is checked on both front and back.
Now for more oddities, if I shut down the PV and recreate it without the passthrough:
And as HVM:
However if I reboot the whole server and try again as PV:
valid_lft 3568sec preferred_lft 3568sec
Which tells me something gets really broken in the host network stack along the way.
Now I could rebuild the kernel again, this time with higher SH_INFO_MAX_VEC (note the source says it should not exceed 128 for some reason) but I’m not entirely sure if I should. I would also need to use the same kernel for both dom0 and domU (not a big problem, but still) , or at least have consistent patches between them.
The config
name = "OVSwitch"
type = "pv" # or hvm
driver_domain=1
memory = 4096
maxmem = 4096
vcpus = 8
kernel = "/mnt/arch/boot/x86_64/vmlinuz-linux"
ramdisk = "/mnt/arch/boot/x86_64/initramfs-linux.img"
extra = "archisobasedir=arch archisodevice=UUID=2024-01-01-16-44-54-00"
disk = [
"file:/opt/xen/isos/archlinux-2024.01.01-x86_64.iso,hdc:cdrom,r",
"phy:/dev/vgroot/ovswitch-root,xvda,w",
vif = [
"mac=00:16:3e:22:85:36,bridge=mgmt-lan-br",
pci = [
# "0:17:00.4",
# "0:18:00.4",
vnc = 1
vnclisten = '192.168.69.1'
vncdisplay = 1
