Okay so I am having a few issues with Manjaro.
So I have updated to 3.19 kernel via their settings manager and I have also swapped to proprietary drivers.
So I used powertop to check my battery draw and its at 13.9W
Here is what Powertop is showing me.
The battery reports a discharge rate of 12.4 W
The estimated remaining time is 1 hours, 51 minutes
Summary: 1368.2 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 93.8% CPU use
Usage Events/s Category Description
495.7 ms/s 545.0 Process /usr/lib/firefox/plugin-container /usr/lib/mozilla/plugins/libflashplayer.so -g
196.8 ms/s 305.2 Process /usr/bin/firefox
54.7 ms/s 236.9 Process /usr/bin/pulseaudio --start --log-target=syslog
4.8 ms/s 162.7 kWork od_dbs_timer
129.4 ms/s 3.9 Process /usr/lib/xorg-server/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten t
5.8 ms/s 42.4 Process xfwm4
538.6 us/s 18.3 Process [rcu_preempt]
7.5 ms/s 8.7 Timer hrtimer_wakeup
4.4 ms/s 8.7 Process /usr/bin/xfce4-terminal
264.4 us/s 9.6 kWork ieee80211_iface_work
16.8 ms/s 1.0 Process powertop
1.5 ms/s 6.7 Interrupt [6] tasklet(softirq)
6.2 ms/s 1.9 Timer tick_sched_timer
1.7 ms/s 2.9 Interrupt [7] sched(softirq)
409.2 us/s 1.9 Process pamac-tray
280.0 us/s 1.9 Process /usr/bin/pamac-daemon
3.0 ms/s 0.00 Timer delayed_work_timer_fn
83.9 us/s 1.0 Process /usr/lib/rtkit/rtkit-daemon
71.2 us/s 1.0 Process /usr/lib/xfce4/panel/wrapper-1.0 /usr/lib/xfce4/panel/plugins/libwhiskermenu.so
68.0 us/s 1.0 Process /usr/bin/ntpd -g -u ntp:ntp
67.5 us/s 1.0 Process /usr/lib/accountsservice/accounts-daemon
51.1 us/s 1.0 Process /usr/bin/wpa_supplicant -u
41.3 us/s 1.0 Process /usr/bin/gpg-agent --sh --daemon --write-env-file /home/xdroidie/.cache/gpg-age
19.0 us/s 1.0 kWork push_to_pool
12.2 us/s 1.0 kWork flush_to_ldisc
Now my CPU should not be in use that much, I have 3 tabs open in firefox and nothing to major in the background so what steps can I take to reduce the power draw on both the battery and the CPU?
Thanks
